Wiper motor measurement please
Does anyone have an original vacuum wiper motor lying around? (I can't count how many I've tossed in the garbage after doing electric conversions)
I need a center-to-center measurement between the two studs on the rocker arm that's attached to the output shaft. Thanks!
1951 Chevy Panel Truck |
Re: Wiper motor measurement please
I'm coming up with 2 inches OC. Per your pic, is that rocker plate original? Looks kinda homemade.
Craig My truck '50 Chevy 3100-5 window If I'm not working on my truck, I'm fishing with the wife or smoking Salmon. Last edited by cmayna; 03-09-2019 at 11:33 AM. |
Thank you so much! That's just a random photo off the web to illustrate the measurement I needed. I'm constructing my own electric wiper system, but it helps to know the factory geometry rather than use trial and error.
aha! Those posts are also 3/8" total in length with 1/4" of each shaft is dedicated for the wiper arms and then with a mushroom head at the end that helps contain the wiper are and the spring clip.
Craig My truck '50 Chevy 3100-5 window If I'm not working on my truck, I'm fishing with the wife or smoking Salmon. Last edited by cmayna; 03-09-2019 at 09:55 PM. Reason: Forgot pic |
