Old 03-10-2019, 06:15 PM   #1
Dachshund
Engine Numbers
Well I THINK the motor in my 47(2) 3600 is a 235, but need to know for sure...
To that end, these are the numbers cast into the head...
3835913 GM1, AND 4B 913 066 570
Could not find any in the block...so far...
So....What do I have?
Dachshund is offline   Reply With Quote
Old 03-10-2019, 10:16 PM   #2
cmayna
Re: Engine Numbers
Are there any numbers on the block behind the distributor?
Craig
My truck '50 Chevy 3100-5 window
If I'm not working on my truck, I'm fishing with the wife or smoking Salmon.
cmayna is offline   Reply With Quote
Old 03-11-2019, 12:40 AM   #3
mr48chev
mr48chev's Avatar
Re: Engine Numbers
As Cmayna asked, there should be some letters and numbers stamped in the machined pad to the rear of the distributor. You may have to clean the paint and or grease off the pad to read the numbers. The prefix letters will tell you what the engine came out of an what size it is. http://chevy.oldcarmanualproject.com/models/engine.htm
My ongoing truck projects:
Old 03-11-2019, 09:18 AM   #4
Dachshund
Re: Engine Numbers
Ok....found this on the boss by the distributor....KBA773764....I THINK its a 54 235....
Old 03-11-2019, 09:34 PM   #5
cmayna
Re: Engine Numbers
According to my searches, K is 1952
Craig
Old 03-11-2019, 10:06 PM   #6
mr48chev
mr48chev's Avatar
Re: Engine Numbers
According to the page that I posted the link to KBA is a 52 216. The engine should have a full side cover that cover the side of the head along with the side of the block.
Old 03-12-2019, 07:42 AM   #7
Dachshund
Re: Engine Numbers
OK... it has the full side cover. The head is apparently a 54 235. There are four valve cover bolts.
Old 03-12-2019, 05:04 PM   #8
mr48chev
mr48chev's Avatar
Re: Engine Numbers
Cold be as guys tended to mix and match parts.
