Old 03-11-2019, 02:52 AM   #26
hatzie
Moderator
hatzie's Avatar
Re: Electrical Gurus - 87' no keyed power
Originally Posted by Greenlee View Post
Thank you Hatzie. Do you think the fusible link could be bad?
Good possibility it's fatigued but not burned out.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-11-2019, 09:10 AM   #27
Greenlee
Greenlee's Avatar
Does this look like what I need? Or is there one that’s better quality than this that I should get? Thanks
https://www.amazon.com/Dorman-Help-8.../dp/B000COD0TW
Greenlee is offline   Reply With Quote
Old 03-11-2019, 09:49 AM   #28
hatzie
Moderator
hatzie's Avatar
https://www.amazon.com/Bussmann-BP-F.../dp/B001BXR9L8
This is not pre-terminated. I usually crimp and solder the ring with heatshrink for strain relief.
The connection to the primary wire should be soldered and covered with heatshrink. Don't leave the off white or black plastic balun on the primary wire. The balun is the oem molded cover for the splice between the fusible link and the primary wire.
If you decide to replace the primary wire use red SXL jacketed 10 ga.
Old 03-11-2019, 08:28 PM   #29
Greenlee
Greenlee's Avatar
Got it. Thanks again!!!
Old 03-18-2019, 12:09 PM   #30
Greenlee
Greenlee's Avatar
Once I got the wire out in the open where I could see it, I found a bunch of exposed copper wire right before the fusible link. I cut it there and crimped and soldered the new fusible link. I put a protective sleeve over the wires to protect them from the headers. I drove it about 50 miles and no problems so far!
Old 03-23-2019, 07:27 PM   #31
pitterpat
I recently went to the UpullandPay to get the wire that goes from the fire wall to the starter, the truck I got it from it had a fusible link on it, my truck didn't have that fusible link. Also so the truck I got it from was a C10, my truck is a C20, Custom 20. The donor truck also had another wire off of that which went to the fuse block on the firewall.
pitterpat is offline   Reply With Quote
Old 03-27-2019, 10:04 PM   #32
wahl4m
i while back my granddaughters pontiac shoebox -kept dying once in awhile -like yours -her stepdad -kept insisting it was a computer problem!-she even stashed a laptop in her car -to ck -it when it went down! i got the car from her & took it to get a new computer or get it reflashed ?? & a great tech at my son in laws chevy dealer ship found it was a battery BAD -not a very old battery ! put a new "delco in it & have not had any trouble in 6 months !!!!!when the car died -it would still crank & seem ok !
wahl4m is offline   Reply With Quote
