Living In The Past
car seats / buckets
Has anyone put car seats in their truck? I have seen a number of you guys install newer truck buckets and such. Is their an issue with the car seats sitting down way too low or something? I suppose if they are too low some nice looking spacer blocks could be made. Just wondering if anyone has done it. any pics? thanks ...
Living In The Past
anyone ???
i put seats from a crown vic in mine...had to put spacers under it to lift them up..power seats and i got them for $30...i can try to get some pics this weekend
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires -'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree -'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials -dads '70 burb (red, 5-7 drop, 350...) www.geocities.com/userc10/truckhome.html AIM: Auntjoedadda |
I got mine out of an 88 4 door Nova. Cost all of 30 bucks. Had to have some 3 inch risers bent to make them the right height. They fit the curve of the gas tank well. They also have manual lumbar and height adjustment lever.
Also used the same in my red truck
I installed a set of buckets from a '72 Chevelle in the '67. I used 2" square tubing to raise them up to the right height. Since these pics, I've removed the incab tank.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
Living In The Past
thanks for the replies and pics!! You guys did nice clean installs. Solver was wondering if those headrests are bent forward a little? Thanks,,, Olden
Half a bubble off!
Someone here on the board had seats out of a Fiero that looked really good. I'll do some looking to see if I saved the pic.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
Mine are out of a Chrysler Lebaron
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
