Old 03-08-2019, 01:18 PM   #1
ShortHaul
ShortHaul's Avatar
Woodgrain Steering wheel trim?
Anybody know if there is a source for the woodgrain trim piece on our steering wheels? My truck came with the original steering wheel, but its missing the trim piece. I've looked high and low, but no luck? Thanks!
This is the part I'm referring to.
Untitled by awesome_adawson, on Flickr
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 03-08-2019, 07:42 PM   #2
69GMC910
MOTORHEAD!
69GMC910's Avatar
Re: Woodgrain Steering wheel trim?
Same question here...!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 03-11-2019, 11:25 AM   #3
tantank79
Count me in as well, need one for my 76
Current: 84 K30 3+3 SRW (2010), 76 C30 3+3 DRW (2015), 83 C10 Suburban (2018), 89 C20 3+3 (2018), 90 K5 (2019), 89 V30 DRW C&C (2019), 78 "Big 10" (2019), 83 K30 3+3 SRW (2020)
Previous: 79 K20 Long Step (03-05), 91 R30 3+3 DRW (11-12), 83 K30 3+3 SRW (13), 86 K30 SRW (16-17), 73 C20 (18), 85 C20 3+3 (18-19), 80 C10 (19-20), 77 K5 2wd (19-20)
tantank79 is offline   Reply With Quote
Old 03-12-2019, 03:55 PM   #4
buffydores
buffydores's Avatar
I just purchased some 3M vinyl woodtrim. It's a great match. Here's mine:
Old 03-13-2019, 10:29 PM   #5
Chief Brody
I've never seen a source for new ones. I have one that I have been saving that the "woodgrain" is not in great shape but the metal itself is. These would be sooo easy to reman...i think. Should be ale to scan these and make them...somebody should be able to...I've been holding onto it for that reason, hoping I could find a place to make one.
Chief Brody is offline   Reply With Quote
Old 03-14-2019, 03:21 AM   #6
ShortHaul
ShortHaul's Avatar
Wow that looks sharp!! Do you happen to have a link?
Old 03-14-2019, 03:23 AM   #7
ShortHaul
ShortHaul's Avatar
I Didn’t realize the trim had a metal piece surrounding the wood. I guess I’m missing the whole piece. If you get tired of holding onto that one I’d be happy to take it off your hands!
Old 03-14-2019, 06:27 AM   #8
buffydores
buffydores's Avatar
Here's 2 second of searching: https://www.metrorestyling.com/Searc...ge=1&cat=19978
Patience and an exacto knife is all you need.
Old 03-14-2019, 07:16 AM   #9
Bandit130
Bandit130's Avatar
Lowe's and Home Depot also has rolls of the woodgrain vinyl.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 03-14-2019, 10:41 AM   #10
ShortHaul
ShortHaul's Avatar
Thanks . I was wondering WHICH of the patterns you chose. It looks like an exact match. Walnut? Cherry teak? Thank you.
Old 03-14-2019, 04:02 PM   #11
buffydores
buffydores's Avatar
I don't recall. I'd try a few of them.
Old 03-15-2019, 02:03 AM   #12
mikelom
Just in case you find the perfect pattern, please let me know.
mikelom is offline   Reply With Quote
Old 03-15-2019, 09:20 PM   #13
franken
I have one of those wheels from a 70s GMC van but the inlay or whatever is orangish not woodgrain.
Old 03-18-2019, 03:13 PM   #14
Leonard60
Gm called that wood grain chestnut on the 1977 models. Not sure the name 76 down though.
Leonard60 is offline   Reply With Quote
Old 03-19-2019, 11:47 PM   #15
ShortHaul
ShortHaul's Avatar
Will do.
Thank you!
