Old 05-28-2004, 10:39 AM   #1
doughby82
doughby82's Avatar
intake leaking oil
on the top of my edelbrock torker intake the middle bolts are leaking oil .its the 2 middle bolts on both sides.should there be washers there o-rings.there are just bolt there now. any suggestions
springfield illinois
2003 custom (harley)built from scratch
68 swb
doughby82 is offline   Reply With Quote
Old 05-28-2004, 11:45 AM   #2
adamls
Gotta Startem Early
adamls's Avatar
I dont think there should be any washers or o-rings. If the bolts are leaking then that means the oil is leaking by the intake gaskets. That oil is also probably getting into the intake passages and cylinders. Is you truck smoking, burning, losing oil.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 05-28-2004, 12:35 PM   #3
doughby82
doughby82's Avatar
it burns oil when you hammer the gas.i belive its running off the intake onto the exhaust though,so its not technicly(sp) burning oil.its just leaking on the top of the intake
68 swb
Old 05-28-2004, 03:10 PM   #4
adamls
Gotta Startem Early
adamls's Avatar
Thats the thing, the only way for oil to get to those bolt holes, is to go past the intake gasket. If it is leaking past the gasket at the bolts, then there is a chance it is leaking into the chambers. You might have the intake checked for flatness. Replace the gaskets with some silicone, should fix it up.
Old 05-28-2004, 03:46 PM   #5
doughby82
doughby82's Avatar
ok ill give it a shot thanks again
68 swb
Old 05-28-2004, 03:47 PM   #6
cdowns
cdowns's Avatar
it's a very common problem , when the intake was installed those bolts should of been treated with thread sealer just remove the bolts clean them up put thread sealer on them retorque the manifold and you'll be good to go,it's doubtfull there's any problems with the intake gaskets
Old 05-28-2004, 07:47 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Try some silicone on the 4 middle intake bolt's....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-28-2004, 11:05 PM   #8
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
There is your fix. On the earlier small blocks, these 4 holes are directly above pushrods for cylinder #'s 3, 4, 5 and 6. Can't remember which cylinder's push rods are below which holes though, I think all exhaust IIRC. Anyhow, one more thing NOT to do is to use a bolt that is too long, as it will either rub the push rod, or worse yet, break it.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 05-28-2004, 11:13 PM   #9
bumpster
Junior Member
Had the same trouble with a with an Edelbrock 2101 intake. I am looking hard at some of the aftermarket bolt sets because some of them are shouldered bolts and maybe I won't cringe when tightning them down. Let us know what works cause i'll bet we aren't the only two with the problem.
72 C10 10 yr.daily driver
68 C10 18 yr.money pit
72 Nova all original
99 H.D. Heritage[sanity check]
71 VW topless bug[summer fun]
"When I have the money, I don't have the time ; when I have the time, I don't have the money.
bumpster is offline   Reply With Quote
Old 05-29-2004, 12:24 AM   #10
1972C10
1972C10's Avatar
I ran some mr gasket 1/2 head intake bolts with shouldered heads still leaked when i had the intake off put some silly on the middle 4 hasnt leaked since..
On my 85 i used exhaust manifold bolts off a 454 85 model used them as sbc intake bolts there shouldered also but 9/16 head some of the 454 3/4 tons had header type manifolds so maybe you can buy bolts for that app cheaper than aftermarket kits.
1972C10 is offline   Reply With Quote
Old 05-29-2004, 08:23 AM   #11
cdowns
cdowns's Avatar
i've found silicone does little to solve the problem but using a high quality automotive thread sealer with teflon in it works every time
Old 05-29-2004, 09:02 AM   #12
Blue Beard
Blue Beard's Avatar
Contact Edelbrock for the proper torque sequence and their recomendations on the issue you have....they are very helpful.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 05-29-2004, 10:04 PM   #13
doughby82
doughby82's Avatar
well this has been my daily driver for about 4 months.but i bought a 2000 chevy truck today.so i will be able to tear into it now.i also have to fix all the crap that happens when you turn them into daily drivers.not bad just some paint chips,and dumbasses with automatic door dingers.
68 swb
