Old 05-27-2004, 05:09 PM   #1
Joey-D
City's Articulation Ramp
Joey-D's Avatar
Angry Rant on Draglinkages
So this is the second time this has happened, but today was the worse. I have an 8 inch superlift with that S-Shaped Drag link that was 2 tie rod ending in it. Last time I went wheeling it got all mis-adjusted when I went to drive over a dead tree on the ground. When I got home, I adjusted everything right, and clamped it together not only with a breaker bar, but then with a 650 ft lb impact wrench. Then I went wheeling today and completely tore one tie rod out of the sleeve. I wasn't even playing hard. That took 2 hours trail side to get it back together because the threads where stripped. It was 90 degrees outside with the humity 100% because it just had stopped raining and every bug that could possibly bite me, bit me. Then worse off, I had to limp home 25 miles in rush hour traffic. This weekend the front clip is coming off so I can replace the power steering pump, lifters, carb, bolt the radiator support down ( They guy I bought the truck from only bolted down one side of the radiator support when he put the 91 burb front clip on) and most importantly CROSSOVER STEERING. Horray, no more guessing if the tires will move when I turn the steering wheel, less wander, a better turning radius, and less stress on the frame! I am stepping off my soapbox now, thank you folks for letting me get that off my chest.
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy
00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver
06 Harley Sporster 883 low
19?? Zamboni, Really I own a Zamboni!
"If your gonna be stupid, then you better be tough."
Joey-D is offline   Reply With Quote
Old 05-27-2004, 05:16 PM   #2
Blazer1970
Blazer1970's Avatar
If you go over 4 inches of lift and you want functional steering, YOU HAVE TO GO CROSSOVER, PERIOD.
Blazer1970 is offline   Reply With Quote
Old 05-27-2004, 07:04 PM   #3
kickinasphalt
kickinasphalt's Avatar
What is crossover steering????
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73
1972 C-10 Longbox,350/350
1998 Pontiac Grand Prix GTP
FOR SALE: 1971 K-10 Longbox,350/SM465/NP205
kickinasphalt is offline   Reply With Quote
Old 05-27-2004, 07:47 PM   #4
stomper72
crossover steering
this is crossover steering
stomper72 is offline   Reply With Quote
Old 05-27-2004, 08:11 PM   #5
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
The steering gear is connected to the right knuckle instead of the left.
Hence "crossover steering".
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 05-27-2004, 10:02 PM   #6
drink2mny
drink2mny's Avatar
Here are a couple threads that explained crossover steering
http://67-72chevytrucks.net/vboard/s...threadid=89313
http://67-72chevytrucks.com/vboard/s...d.php3?t=90094
Support The Board
drink2mny is offline   Reply With Quote
Old 05-27-2004, 10:32 PM   #7
Devil'S Ride
Time fer me to go to crossover....I took my rig in to have it aligned today, an on the way in, i noticed a grinding that hadnt been there before......yeah, bearings, tie rods, drag link, all the bushings, an **** ton of other stuff is shot on my truck, so instead of a 40$ alignment, Im walkin out of there tomorra about 500$ lighter..... so crosover is definetly on the list when I get the new lift.....that an my power steering box is broke now.....
argh...sorry hijack the thread, but I understand your frusteration Joey-D
The Devil
1983 ONE TON 454/400/208 11" of lift on 44's
Devil'S Ride is offline   Reply With Quote
Old 05-27-2004, 11:03 PM   #8
Joey-D
Joey-D's Avatar
I hate getting alignments, everytime I go its one of two things: "We can't do an alignment until you replace this, this, this, and that, then maybe it'll work" or "I am sorry sir, the $49.99 is for regular vehicles, since you have modified suspension and are oversized, the new price is $199.99, your first born, and could you please just go ahead and bend over for us now" But truefully, the differnce is night and day.
Old 05-28-2004, 04:08 PM   #9
Joey-D
Joey-D's Avatar
Check out this site on crossover, hi steeer, inverted T type, and inverted Y type steering; it's everything you could have ever wanted to know.
Everything Ever Know About Crossover Steering
Old 05-28-2004, 05:02 PM   #10
Bobalouie
Fetzer Valve Technician
Bobalouie's Avatar
I looked at the info site, very informative. I have one question, how do you mount a steering stabilizer if you use hy steer crossover steering? Or do you not need one anymore?
1972 Chevy K10 SWB
Bobalouie is offline   Reply With Quote
