Old 03-22-2019, 11:31 AM   #1
solidaxel
solidaxel's Avatar
Dead Cylinder 5.3 2016
Lost compression in Cyl.# 7 only
Has anyone experienced this problem?
Went into limp mode!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-22-2019, 11:58 AM   #2
beaterku
beaterku's Avatar
Re: Dead Cylinder 5.3 2016
If I were a betting man, I would say the #7 DOD lifter failed. Common problem.
beaterku is offline   Reply With Quote
Old 03-22-2019, 01:20 PM   #3
solidaxel
solidaxel's Avatar
Well, I guess with all the gas I have saved with DOD there should be more than enough to cover the repairs!!
Do they change all lifters on both banks?
Sounds expensive??
Is there a permanent fix, or are we looking at this happening in another 80K miles?
LS 3 4L70E
Old 03-22-2019, 02:41 PM   #4
sprint_9
sprint_9's Avatar
Interesting I thought they had these somewhat fixed, especially with the gen 5. I assume it's a gen 5 in 2016. I had similar problems on my 07 but they had a design flaw, well the entire concept is a design flaw as far as I'm concerned.
Have you pulled the valve cover and inspected things? Maybe pull the rocker arms off and make sure nothing else is bent or broke.
sprint_9 is offline   Reply With Quote
Old 03-22-2019, 03:40 PM   #5
beaterku
beaterku's Avatar
Sounds expensive??
You can swap use a DOD delete kit. The heads have to come off if it is in fact a dead lifter so might as well when you are in there.
The brand new 18's are doing it. It's strange that GM hasn't found a solution yet.
Old 03-22-2019, 04:12 PM   #6
skyphix
Yep - agreed on GM not finding a fix. I know the 07 - 12 or so suffered premature engine failure issues due to loss of oil pressure when the lifters died. I guess at least now you just lose compression in a cylinder?
DOD kit is the only way to go, then getting it flashed to disable it in the ECU as well.
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
Old 03-23-2019, 12:34 AM   #7
sprint_9
sprint_9's Avatar
I might have to buy a Range Disabler for my 14, I dont want to deal with this crap again.
Old 03-24-2019, 08:05 AM   #8
Rich84
Rich84's Avatar
I am using one with my 2016..gas mileage is about the same. Like the way it drives much better.
Rich84 is offline   Reply With Quote
Old 03-24-2019, 10:48 AM   #9
ls1nova71
ls1nova71's Avatar
Just disabling the system isnt a foolproof method, since you still have the DOD lifters in the engine which is the part that fails. Just because they aren't operating doesn't guarantee they will not fail.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-25-2019, 11:40 AM   #10
First c10
First c10's Avatar
I deactivated the DOD on my sons truck but the oil pressure is something I always worry about because I know its not if a lifter is going to fail its when.
We plan a DOD/VVT delete soon!
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-25-2019, 07:11 PM   #11
sprint_9
sprint_9's Avatar
I agree its not fool proof, but by not operating them the failure rate goes down considerably with minimal effort. The part that usually fails is the pin, either by wear or by being out of time. Keep it locked and two of the main problems are no longer issues.
