Old 03-27-2019, 05:13 PM   #51
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Final mock-up pics, whatdaya think?
Originally Posted by weim55 View Post
Curious, were you able to retain the original dually Cab and chassis rear axle? If so how did the placement of the original wheel wells in the bed work out for tire clearance?
Steve weim55 Colorado
No, I had to shorten the frame 6” in front of the rear wheels and cut about 8” off the rear. The C-30 wheelbase is 133” and a normal LWB with an 8’ box is 127”. To get the correct width rearend, I changed it to a 14 bolt from a ‘97 C3500. The original rearend was much narrower and would have required tubbing to run it. The look I was after was the wide rear “hips” that all dually pickups made after 1973 had.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-27-2019, 07:05 PM   #52
67_C-30
67_C-30's Avatar
Here she is is all cleaned up.
A little quick clip of her purring like a kitten. https://m.youtube.com/watch?feature=...&v=mo1y5XQn3XY
My trucks
Old 03-27-2019, 07:13 PM   #53
67_C-30
67_C-30's Avatar
Dp
My trucks
