Old 03-22-2019, 12:15 AM   #1
cornerstone
cornerstone's Avatar
Another pinion angle question
I think I know what the right thing to do is, but I’d rather have y’alls brains in on this as well. Here is the situation... I went to a local driveshaft shop in town and inquired about ordering a new driveshaft with a slip yoke for my 6L80E. After our discussion he told me I need to have my pinion angle set at ride hieght before I measured for the driveshaft, since the length would change as the axle rotates either up or down. That sounded smart.... so here’s what I have currently.
My differential is angled up 7 degrees and my transmission is angled down 4 degrees. Since it needs to be within .5- 3 degrees of parallel, I think there may be 2 or 3 options here. The first is to shim the differential down 5 degrees. The second option is to drop the tail of the transmission another by 2 degrees. Or there’s the third option which would be to find a compromise between the two. Am I way off here? Thanks in advance!
Brian
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-22-2019, 01:49 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Another pinion angle question
4deg down on the trans isn't terrible...but the diif needs to match the trans angle.. if you could drop the diff 3deg to make it 4deg, it would be good...I wouldn't try to make the trans match the diff....to much angle
the 3deg up/down is just kind of a unsaid rule of thumb for driveline setup..
do you have all your body on the truck? if your on trailing arms that angle will change when under full load of body
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-22-2019, 10:21 AM   #3
cornerstone
Thanks Mongo! Just the man I was hoping would answer. These measurements were taken with the frame level on jack stands at what I am guessing ride height to be. This is the first truck I’ve done with air ride, and the variable hight is requiring more brain power than I can muster to figure this out.
Brian
Brian
Old 03-22-2019, 06:37 PM   #4
Willie Makeit
Willie Makeit's Avatar
don't worry about the variance, just measure at ride height. the rear end should have parallel angles to the trans. 4 degrees down at trans = 4 degrees up at rear end.
EDIT for clarification: this is in regards to a 1 piece driveshaft only. 2 piece shafts are a whole new can of worms.
Willie Makeit is offline   Reply With Quote
Old 03-22-2019, 11:48 PM   #5
Captainfab
60-66 Nut
If your truck has trailing arms and 2" drop blocks, these will solve your angle problem.
http://www.67-72chevytrucks.com/vboa...d.php?t=782895
Old 03-28-2019, 10:29 AM   #6
cornerstone
Thanks Willie Makeit, thanks Captainfab. Currently I don't have lowering blocks on the truck, so I probably will get a set of those from you Captain. Do you offer any other angles besides 2.5 degrees?
Brian
Brian
Old 03-28-2019, 05:07 PM   #7
scoot_mcgrute
I used this article as a guideline for my pinion angle. Basically, you want the total angle at the differential to match the angle at the transmission. I have no vibrations up to 130 on the dyno using this method.
https://www.quickperformance.com/Pin...9gsB0TthqnQBJs
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 03-28-2019, 11:56 PM   #8
Captainfab
60-66 Nut
This one set of 2.5* blocks is all I have. A local guy I know needed something to correct a pinion angle issue, so I made 2 sets.
Brian
