03-28-2019, 08:01 AM | #1 |
78 big 10 gear lube capacities?
I need to get a service manual but does anyone have the approximate lube capacity for the 4 speed manual trans (SM465?) and the 78 factory differential? Just need to know how much to buy.
03-28-2019, 10:22 PM | #2 |
Re: 78 big 10 gear lube capacities?
2 gallons should do it if I remember correctly
87 V20, Vortec 350, Sm465, Np205, Dana 44, 14bff 4.10's |
03-29-2019, 05:30 AM | #3 |
Thanks!
03-29-2019, 04:33 PM | #4 |
I just changed mine a few months ago. I took about one gallon to the bottom of the fill hole. I think the true capacity is just a bit over 1 gallon, but I have a leak at the front of the transmission, so I will have to top it off periodically.
I got the cheap 80-90 at Autozone, since I am cheap and the truck is old and leaking the stuff. |
03-29-2019, 04:56 PM | #5 |
Thanks ! I am doing the differential this weekend because the cover is leaking. I will get the transmission another time.
