03-28-2019, 04:24 PM | #1 |
Drop spindles 67-72/73-87
Im in the market to buy 2.5 drop spindles for my 71 front disc brake c10. Was reading that I can purchase the 73-87 (CP4S4) spindles and just change the upper/or Lower ballpoint. I also replacing my 1.25 rotors. I guess my question is what is the benefit of using the 73-87 spindle. I'm already plan on taking everything apart so if beneficial might as well do the spindle upgrade. Any recommendations ot info is already well appreciated. Thanks in advance.
03-29-2019, 01:14 AM | #2 |
Re: Drop spindles 67-72/73-87
http://67-72chevytrucks.com/vboard/s...d.php?t=438758
lolife99 "Same control arms from 67-72. Those spindles are 73-87 spindles. They are cheaper because the balljoints and tie rods are cheaper. All drop spindles (with the exception of CPP's modular spindles) are designed after the 73-87 spindle. The tie rod holes and balljoint holes are just reamed different sizes. This is why they can make a different spindle for all the years. 60-62, 63-70, 71-72, and 73-87." |
03-29-2019, 04:26 PM | #3 |
Is going with a larger upper ball joint a good thing. Looks like I would also need to change the tire rods and sleeves to upgrade to 73-87 spindle
03-29-2019, 04:53 PM | #4 | |
67-72 parts collector,…
Change your upper ball joint and outer tie rod only. Lower ball joints are the same. I see zero benefit in using 73-87 drop spindles over 71-72 drop spindles. Same casting. Just different tapers on the holes.
03-29-2019, 05:49 PM | #5 |
Appreciate the info
