5.3 level sensor a quart low or right.
I am tearing a 02 truck 5.3 down to the short block here over the next few weeks. Just replacing the seals and a couple sensors before throwing it in.
My headers are going up so that level sensor will be exposed and easily seem. Planning on just blocking it off. But was thinking about drilling/welding a straight or 99 to the blockoff plug and having a sight tube eliminating the dipstick completely. I have a clear tube from granger made for oil and 350F that I used on a sbc modifying a 4qt pan and eliminated the dipstick on that engine. I would like to do the same on this 5.3. If the oil level sensor is a quart low I could install a 90 to the correct height marking the tube if need be. If it is correct then I will go straight out then 90 up letting me see that oil is up to the right level in the clear section of tube before the 90. The 90 will have a tube going up to the catch can letting me open a ball valve and drain that contents back into the oil pan. I am guessing it is a quart low. But i want to make sure.
1991 Metro commuter 1991 s10 future project truck 1987 V10 backup daily/junk truck 1985 K20 Winter beater 1991 R30(squarebody) c/c flatbed towrig 1994 s10 80"wb custom build |
Re: 5.3 level sensor a quart low or right.
read it wrong . carry on .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
![]() ![]() Join Date: May 2015
im not even sure how you can see it...I cant see mine...but I see you say you headers are going up......and I don't know about the tube idea...id be scared a rock would fly up and bust it...dipstick works just fine for me.. my vett pan has a nice screw in plug in there though
![]() Join Date: Sep 2005
on my 5.3 suburban low oil level does not come on till its 2 qts low on oil
