Old 03-15-2019, 07:21 PM   #1876
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Originally Posted by knomadd View Post
You need to make a trip to Lone Star Thorwdown (LST) next year, when it's finished. It's out here just north of Houston in February.
Ha, you’re more optimistic on schedule than I am. We are definitely planning on hitting all of the good stuff once we’re down that way
Originally Posted by smbrouss70 View Post
Very nice!
Originally Posted by Kronald_70GMC View Post
Damn! Them some fine looking pieces you got there. Good work!
Originally Posted by C10_ustacould View Post
That interior is going to be outstanding! Nice job
Originally Posted by TA_C10 View Post
Sweet! Those look great and will compliment your truck nicely.
I want to upgrade all my stuff now.... It's hard to resist the urges, heck my stage 1 build is already more like a stage 1 and 2 combined.....
Thanks guys, it never ends...
Originally Posted by SCOTI View Post
Blue Houndstooth? What's the color/info on the other material? I'm on the hunt for retro (appearance & color) blue material that doesn't break the back.
Look for ENDURATEX Madrid 2309 CLASSIC Metallic Medium Blue Vinyl
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-15-2019, 07:48 PM   #1877
SCOTI
SCOTI's Avatar
Have you found a rattle can dye that matches the vinyl?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-15-2019, 10:26 PM   #1878
rustytruck50
rustytruck50's Avatar
That upholstery is pretty sweet and really goes the extra mile to make the truck unique!!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 03-16-2019, 01:09 PM   #1879
gringoloco
A guy with a truck
gringoloco's Avatar
The last can I used was ordered from a Corvette restoration shop, as those cars used the same blue metallic vinyl. I don’t know how close this vinyl I’ve ordered will match the stock stuff, though, which is why I had them go ahead and re-cover the visors and dash pad, too. I can do a comparison against my armrests, which were painted with the rattle can, once the new pieces arrive.
Thanks for the kudos. Going for stock-ish, but not quite. Most non-C-10 folks probably won’t even look twice
-Chris
Old 03-16-2019, 02:17 PM   #1880
knomadd
knomadd's Avatar
You can do it! It doesn't have to be "done." It doesn't even have to run, but it's a lot easier to get in and out if it does.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-16-2019, 03:57 PM   #1881
SCOTI
SCOTI's Avatar
I'll watch for the updates. Thanks!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-16-2019, 08:12 PM   #1882
Last_Paladin
Did I miss it? How'd you get a MAF into the air cleaner?
Last_Paladin is offline   Reply With Quote
Old 03-16-2019, 10:00 PM   #1883
gringoloco
A guy with a truck
gringoloco's Avatar
I’ll just be happy to have it together enough to get on a trailer in a couple of months
No worries, should have everything in a few weeks
MAF-less, speed-density via Fitech, but Holley’s new Terminator X is looking pretty good to me now. Check out dayj1’s “another way to skin the cat” thread for a good example of how to hide the MAF in a tall air cleaner. I’ve also seen guys use the cartridge type in the snorkel
-Chris
Old 03-16-2019, 10:12 PM   #1884
gringoloco
A guy with a truck
gringoloco's Avatar
My new bellhousing arrived and I got right to bolting it on and stabbing the transmission. You can see just under the top-most bolt where the alloy unit has more clearance than the old Lakewood steel one. This is where the rear cover bolts needed some wiggle room. The new one is from Silver Sport, and is made specifically for LS to Muncie conversions. Should also work well with a TKO, if/when I decide to go that route and saves what feels like 60 lbs...
No pictures of the hydraulic throw out, but it set up beautifully with proper clearance. I couldn’t resist bolting up the Hurst shifter and pretending to row through the gears
-Chris
Old 03-16-2019, 10:20 PM   #1885
gringoloco
A guy with a truck
gringoloco's Avatar
...and a few shots of the engine sitting in its rightful place. I particularly like the last one showing how nicely everything tucks up with the dropmember.
-Chris
Old 03-17-2019, 12:02 PM   #1886
smbrouss70
smbrouss70's Avatar
You are making me want to do an LS swap....
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 03-17-2019, 12:12 PM   #1887
gringoloco
A guy with a truck
gringoloco's Avatar
Jump on in, everybody’s doing it! Once this junk is “done”, I’ll be happy to come help
-Chris
Old 03-17-2019, 02:20 PM   #1888
SCOTI
SCOTI's Avatar
Swap is looking on point!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-17-2019, 03:41 PM   #1889
shearjs
shearjs's Avatar
Everything looks great! What size is that booster/master set up? Is that a captain fab bracket hiding behind?
shearjs is offline   Reply With Quote
Old 03-18-2019, 01:05 AM   #1890
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks Scoti!
Thanks, the booster is a 9” dual diaphragm from inline tube, wilwood master, and captainfab bracket with integrated clutch master
-Chris
Old 03-18-2019, 11:37 AM   #1891
aggie91
I'm just glad to be here!
aggie91's Avatar
Looking good from here!
Nice job Chris.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-19-2019, 10:01 PM   #1892
lks dcvn
lks dcvn's Avatar
Just spent the last week going through this build thread and found myself writing down ideas to follow up on and parts to look into for a few of my builds.
Excellent work on all fronts Chris - you are doing top notch stuff!
What shifter boot are you considering for the Muncie? I replaced the one in the 70 GMC Jimmy with a new one (Amazon cheapie) and it ripped after using it for driving in/out of the garage... I should have known.
lks dcvn is offline   Reply With Quote
Old 03-19-2019, 10:06 PM   #1893
TA_C10
TA_C10's Avatar
That engine is looking sick in the bay man. Top Notch.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 03-19-2019, 11:27 PM   #1894
gringoloco
A guy with a truck
gringoloco's Avatar
Nice job Chris.
Thanks for the compliments, everyone. I just do the things I think are cool, I’m glad others seem to like it as well
As for the shift boot, the plan is for a factory (or re-pop, most likely) oval-shaped 4wd boot and trim ring, just keeping with the stock-ish theme. Hurst makes this handy little piece to adapt the flat handle to a round-ish boot hole:
https://www.hurstshiftersonline.com/...ommet-p590.htm
-Chris
Old 03-19-2019, 11:48 PM   #1895
gringoloco
A guy with a truck
gringoloco's Avatar
Had some power steering hoses made-up at the local hydraulics shop yesterday. Quick turn, cheap, and fit nicely. The high-side snakes behind the tensioner bracket, while low side has a pretty much straight shot to the reservoir.
That allowed pressing-on of the pump pulley and then measuring for the serpentine belt. I’m happy to report that it only took two trips to the LAPS to get the right one Baby steps...
-Chris
Old 03-20-2019, 03:28 PM   #1896
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
You're killing it Chris, one step at a time. Your patience and eye for detail are paying off for sure!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 03-21-2019, 03:50 PM   #1897
rustytruck50
Wow...the fit of the engine in that drop member is perfect....I dont know if you could even fab something remotely close to that at home!
-Doug
'05 RCSB Sierra 2WD
Old 03-21-2019, 04:47 PM   #1898
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, buddy! I may have to back off on the detail work for a bit, it’s time to get this beast running!
Not with my skill set, I know my limitations Definitely a high quality product
-Chris
Old 04-05-2019, 11:06 AM   #1899
halfstep
Great truck - great work!
...saw that you had some questions re. the clutch rod angle set up on another post and I'm working on the same subject so I thought I'd get you some photo's of an alternative set up - couldn't send photo's via PM so I'm using this post. Might help you and/or others:
This is the NO LIMIT this set up for hydraulic clutch and looks much more straightforward - pulls the clutch master up higher, rod is straight, is on a flatter firewall area and uses the more popular mounting style master which allows for larger and/or remote reservoir. Plate is 3/16"
halfstep is offline   Reply With Quote
Old 04-05-2019, 02:53 PM   #1900
gringoloco
A guy with a truck
gringoloco's Avatar
Appreciate the compliments The NL stuff looks nice, wish I’d known there was another option. I’m pretty far down the road with my current setup, so I’m running with it for now. Thanks for the heads-up!
-Chris
