Flamin' Bass
Steering wheel wobble - fix?
I have a '67 C-10 with PS and Grant steering wheel installed by the PO. You can move the steering wheel side to side/ up to down on the stock (non-tilt) column. The wheel is tight on the shaft, but it looks like the shaft is sloppy in the column.
I looked on a few parts suppliers on the board, but only found replacement parts for the tilt columns. Anyone know where I can get the (bushing/bearing?) for the upper part of the column; assuming that's what the problem is? Thanks,
Rick Olson /nosto/ Galloway, NJ Pics : http://community.webshots.com/user/nosto53 1972 Triumph TR6 - full resto, now with a Toyota 5-speed 1975 F**D F-100 - rusty, but reliable 1982 HD XLH-1000 1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!! |
Almost done!
I've got one but the shipping would be more than you could purchase one locally. If you can not find one, pm me and I give you one for the cost of UPS. But you should be able to find one...Kelly
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
Check the spring at the bottom end of your column, there is a spring about an inch long that tensions the column shaft. Yours may be weak or broken.
72 Cheyenne Super 4x4 SWB |
Junior Member
You can get the bearing from your local Chevy dealer. I don't have the part number, we tossed the bag when we fixed the kid's column.
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
I replaced the upper steering colum bearing on mine for the same reason, and it made no difference at all with the side to side & up and down play. Interesting what Jeepster376 says about the broken or tired spring at the bottom of the column I'll have to look into mine as well, (great tip). Doug
