Old 04-02-2019, 10:12 PM   #451
Thrill4130
Active Member
Thrill4130's Avatar
I found some newer metal with diamond pattern to fix my window gap issue I had. Stripped the other panels to raw aluminum and will polish later. Now time for the top metal.
Thrill4130 is offline   Reply With Quote
Old 04-04-2019, 09:46 PM   #452
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: What did you do to your truck today.The 3rd chapter
Picked up some parts, installed some parts, including the LH manifold. "Can't" do the RH manifold, decided to strip the powder coat off the A/C bracket to exhaust manifold in favor of ceramic. Coating guy says that one is free, so what the heck. Not taking any chances it melts all over the "new" manifold. Slow moving, but will get there eventually.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-05-2019, 11:11 AM   #453
Ken O.
I put new LED tailights in the 67 GMC yesterday. Also installed the new led compatible flasher. Boy does that make a difference! I got new amber LED bulbs for the front that I'll put in this weekend.
Ken O. is offline   Reply With Quote
Old 04-07-2019, 02:58 PM   #454
72c20customcamper
72c20customcamper's Avatar
Got the transmission back. But there is a problem with the converter. It will not fully seat. Has me stumped never had this problem . So I'm bringing to the shop to let them figure it out. I got the converter from them as part of the rebuild. But I did manage to get the trans crossmember out. What a *****. Ended up grinding and drilling out the rivets that hold the wings on. Really see no reason for them but I'll just bolt them back in place. The crossmember was in remarkably good shape.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-07-2019, 09:14 PM   #455
zicc1835
zicc1835's Avatar
what I did with it, today this truck sits in my garage all winter used it today to take advantage of the Home Depot sale on mulch....spring has sprung
zicc1835 is offline   Reply With Quote
Old 04-07-2019, 09:25 PM   #456
rjs53
Got the inside of the cab cleaned up. Wiped all the dust and spills from painting and it sitting in the garage for a year during work. Then laid the carpet.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 04-07-2019, 09:27 PM   #457
Greasey Harley
Greasey Harley's Avatar
I bought 24 bags of red @ 2 bucks a bag
Great deal!
Got my truck out for the first time this year too.
Spring has sprung indeed !!!!!!
Greasey Harley is offline   Reply With Quote
Old 04-07-2019, 09:43 PM   #458
Boog
laying low
Boog's Avatar
This reminds me. My sister told me be careful of handling bags of mulch and potting soil. Someone she knows found a snake and eggs in a bag that had either a hole in it or had been previously opened.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-07-2019, 09:46 PM   #459
zicc1835
zicc1835's Avatar
thats good advice ....getts nice and warm in them bags....
Old 04-07-2019, 09:52 PM   #460
cornerstone
cornerstone's Avatar
Had to buy a new tool. Astro 1442 Riv-Nut tool. This thing will come in handy! Installed my high hump.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 04-07-2019, 10:06 PM   #461
Thrill4130
Active Member
Thrill4130's Avatar
Went to get knobs but left with manual column and the whole dash. Pumped on cluster with no cracks and throttle knob. Also, put two windows in the camper shell. Need to finish before car show next weekend.
Old 04-07-2019, 10:10 PM   #462
zicc1835
zicc1835's Avatar
that topper has really turned out nice.....real craftsmanship there..
Old 04-07-2019, 10:51 PM   #463
Thrill4130
Active Member
Thrill4130's Avatar
Thanks it’s been a fun learning lesson.
Old 04-08-2019, 02:08 AM   #464
3757chevy
3757chevy's Avatar
Topper Turned out real nice.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 04-08-2019, 06:32 AM   #465
Redneck Rydes
Redneck Rydes's Avatar
Wow, great job on that!
Redneck Rydes is offline   Reply With Quote
Old 04-08-2019, 05:48 PM   #466
Metaldoc
Metaldoc's Avatar
New shifter for the 5 speed. Looks more 1967. I'm thinking it needs more character, maybe some sweeping bends.
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
Old 04-08-2019, 06:04 PM   #467
nlped
nlped's Avatar
After seeing your post, I ordered one of these too. I told my wife it was your fault.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-08-2019, 07:31 PM   #468
72c20customcamper
New master cylinder on the 68 and adjusted the brakes. New motor mounts on the 72. Transmission guy called the trans is all ready to go. He had to change the front bearing again now the converter slides right in .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-11-2019, 12:08 PM   #469
SoCoC10
SoCoC10's Avatar
Dash installation is complete on the 71 K10 Cheyenne. New Saddle dash pad, new cluster housing, new heater ducting, new steering wheel. Factory tilt column cleaned up nicely. Doors are next, then carpet and I'll finally get the Truck World Super Saddle seat in it. Can't wait
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 04-11-2019, 12:19 PM   #470
siggyfreud
siggyfreud's Avatar
Originally Posted by Chris_oz View Post
I got tired of trying to get my old distributor to run as it should....so I fitted a new HEI unit.
Works perfect and timing curve just as I wanted.
Even the Tach still functions as it should.
Goes so much beter, now it will spin the tyres if you like, or sit on 70mph with ease.
Is that the Amazon unit for like $60-70? I've used it on two builds now and been very pleased with them so far.
siggyfreud is offline   Reply With Quote
Old 04-11-2019, 03:56 PM   #471
Metaldoc
Metaldoc's Avatar
Drink holder doesn't hold my milk or my Vernors in a cold sleeve and needed a place for the phone.
Old 04-12-2019, 06:25 PM   #472
RodnRudy
RodnRudy's Avatar
Got my short block back from Schmidt Automotive today. I've been chasing a vibration in the GM crate engine every since I've had it. So I had them bore it .030, new domed pistons and new rods and bearings. Had the whole assembly balanced to boot. Old Red ought to run a lot better and have more oomph too boot. Raised compression from 8.5 to 9.4 with the domed pistons.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 04-12-2019, 11:39 PM   #473
Metaldoc
Metaldoc's Avatar
I need more sound up front so I swapped out the old dead speaker for two 4". Then the old dead radio was in the way so, customized. Still need some brackets but it all fits. added another amp just cause.
Old 04-13-2019, 08:54 AM   #474
NewBayColony
NewBayColony's Avatar
Keep us up to date on this. What are you using for a head unit?
72 C20 292 3OTT
77 GMC 2500 4x4 Longstepper 350 4sp
50 3100 ex Airforce/Town of Mendon fire truck
72 GMC 1500 2wd short stepside 250 4sp
78 GMC 2500 4x Longstepper 292 4sp
54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman)
NewBayColony is offline   Reply With Quote
Old 04-13-2019, 11:38 AM   #475
machas74
I added kick panels with speakers. Stereo is next.
machas74 is offline   Reply With Quote
