70 c-10 questions
How could I tell what orig. equipment came on my truck?
Everything looks like it's been there for 30+years but is there any way to tell for sure? Also how to tell if it's the orig. motor? 1970 c-10 stepside, a/c, p/s, p/brakes, 350 2bbl,3spd auto, posi. Thanks. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
You can look on the option's sheet on the glove box door if tiis still there....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Running on empty
You can also try locating the 'build' sheet for the truck;
It may be located under the seat or in the webbing behind the seat back; some have claimed to find it behind the gas tank; good luck you might just find it
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver ![]() |
