#51 |
Re: 22" GM Transport Steel Wheels on Square body? Anyone?
Looks good
#52 | |
As for a template, it really depends on the clips you get. If you go with the #capclips from struggle_55 on Instagram, his come with a template. His clips are his own design though, so the template wont work with other available clips. I used the Mobsteel clips on mine. They are pretty much the only other clip design out there. I just put the cap on the wheel, traced the outside, and then held the clip in place by hand and marked where I needed to drill the hole such that the edge of the clip just touched the line I traced. To be honest, these clips aren't that great and I wish I would have gone with struggle_55's clips, but at least so far I haven't lost a cap.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 | Oscar the 70 C10 - C10 Concept/Development Photos: Master Thread |
#53 | |
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
#54 |
Do anybody know if these will fit on the 4x4 hub?
#55 |
All of the ones I have seen are on newer GM 6 lugs so, the wheel center bore is smaller than the older Chevy 6 lug 4x4s...
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! ![]() 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
#56 | |
They can have the back spacing altered, They can have the bolt pattern changed to 5 or 8-lug. They can be widened (widest I've seen are 12.5"). It all comes @ a cost. I see them for $550 (unmodified 22x9 6-lug's) up to $1650 for staggered size, deep offset, 5-lug set-ups.
#57 | |
#58 |
Thought I would show Frank. My 86 Sierra. Soon to be a carbed LS, 700r4, and a bit more.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#59 |
Has anyone seen a beauty ring for these wheels?
| Bookmarks |
