Old 04-03-2019, 11:02 AM   #1
6768chevylover
6768chevylover's Avatar
np205 reseal, on vehicle!
I need to reseal the retainers for the front output and the rear output. Is it possible to do this with it on the truck if I was to move the cross member out of the way? also the rear retainer is the 8 bolt retainer not the small 5 bolt retainer. Is that doable on the truck or does it need to come out?
6768chevylover is offline   Reply With Quote
Old 04-03-2019, 11:04 AM   #2
kwmech
Re: np205 reseal, on vehicle!
Rear output 8 bolt retainer you'll have to be careful with removing the assembly as not to drop the needle bearings into the case. It can be done. I would question the input seal at this point if everything else is bad
Old 04-03-2019, 11:50 AM   #3
6768chevylover
The sm465 is my transmission. Its full of oil everytime I check it so I'm sure the seal is prolly fine.
Old 04-03-2019, 06:37 PM   #4
jocko
jocko's Avatar
You've probably already seen this - and I realize your goal is to do this on the truck - but there are some great ref pics in this thread that may be helpful regardless of which route you take. http://67-72chevytrucks.com/vboard/s...d.php?t=469726
Old 04-05-2019, 10:08 AM   #5
Mine needs it, too. I'll be dropping mine. I figure it's time to do the adapter and transmission, too. Mine's a TH350.
Old 04-05-2019, 11:06 AM   #6
57taskforce
All about them K’s
57taskforce's Avatar
Mark is dead on here. This is a really good write up. I used it for reference when I did the bearings and seals in the 205 in my K20.
Tyler
Old 04-05-2019, 11:44 AM   #7
jeffahart
jeffahart's Avatar
Well, once the cross member is out the transfer is as good as out. Nothing in the way of dropping it. Keeping it in is no longer a shortcut. Biggest hassle is unbolting the front shaft, it's in a bad spot, but easy access if you remove the hump. If you are not sure about wrestling the 205 down I can give a couple tips. I do mine on the ground by myself.
j
White K20
jeffahart is offline   Reply With Quote
Old 04-15-2019, 02:26 PM   #8
6768chevylover
I bit the bullet and removed my T case from the truck and have been resealing it. My question is will 90w gl4 oil be fine for this?
Old 04-15-2019, 04:07 PM   #9
6768chevylover
Sorry! for the refill of the tranny.
Old 04-15-2019, 07:40 PM   #10
jeffahart
jeffahart's Avatar
Yes use it for both. Gl4 it's better for the synchros in the transmission
J
White K20
Old 04-15-2019, 07:42 PM   #11
jeffahart
jeffahart's Avatar
Also make sure you use the gaskets no sealant when mounting the adapter to the T case and transmission. Those tolerances are very important
J
White K20
Old 04-15-2019, 07:47 PM   #12
jeffahart
jeffahart's Avatar
Smile Re: np205 reseal, on vehicle!
Another also. Some of the bolt holes on the PTO covers are through bolts. You might want to dab a little sealant on the threads. I think a couple bolts on the transmission side of the adapter are through bolts too. Just look at them all. I added a dab of thread sealant to a few of my bolts. I have no leaks, and I am happy.
J
White K20
