03-08-2019, 10:54 PM | #1 |
Hubcap fit
Will this style of Hubcap fit '68 16" C20 wheels?
03-09-2019, 05:24 AM | #2 |
Re: Hubcap fit
I don't think so. Pretty sure those are for 15" wheels. Plus I don't think they'll fit over a "Floating Axle" Hub on the rear.
03-09-2019, 10:27 AM | #3 |
Re: Hubcap fit
what pepper said. For 15" wheels on a 1/2 ton only for those.
03-09-2019, 10:38 AM | #4 |
Re: Hubcap fit
Yep, a big fat NO
03-09-2019, 12:34 PM | #5 |
Proprietor of Dale's Corner
Re: Hubcap fit
3/4 ton didn't have wheel covers. I agree that the pictured covers are 15" 1/2 ton caps.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
03-09-2019, 12:56 PM | #6 |
Re: Hubcap fit
OK, Saved me some money there..
So the C20 didn't have Wheel covers?,.. which Hub caps? |
03-09-2019, 01:16 PM | #7 |
Re: Hubcap fit
They got the small grey dog dish type
03-09-2019, 01:18 PM | #8 |
Re: Hubcap fit
These. Chrome with black ring also
03-09-2019, 02:10 PM | #9 |
BlahBlahBlah
Re: Hubcap fit
I dunno if you saved money. Those small caps seem to be very rare and expensive when you find a nice set.
03-09-2019, 02:20 PM | #10 |
Moderator
Re: Hubcap fit
Post a pic of your wheels, that will tell us which style hubcaps you can use.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
03-09-2019, 04:03 PM | #11 |
Re: Hubcap fit
Here is a pic of my truck, '68 C20 CST.
03-09-2019, 11:11 PM | #12 |
Re: Hubcap fit
69-75 style in chrome or stainless. There were painted as well, which ran later. Then there are 76-91 hubcaps. There were also wheelcovers GM trucks beginning in '78 I believe. There are a couple styles of those for 16" wheels. The 76-91s will be your easiest and cheaper option
04-15-2019, 07:34 PM | #13 |
Re: Hubcap fit
So I bought a set of those hubcaps, they fit on the front fine, but they didn't fit the rear due to the rear hubs, so I made them fit by cutting out the centers..Ha, so sue me..
Are there caps that fit over the rear Center hub like this??
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
04-15-2019, 09:10 PM | #14 |
Re: Hubcap fit
more than one way to skin a cat
but I'm curious, if they fit 8 lug wheels, why not over rear hubs
I started out with nothing - and I still have most of it |
04-15-2019, 10:42 PM | #15 |
I have a radical idea!
Re: Hubcap fit
The rear hubs are shorter on the 14 bolt rearends that those hubcaps were designed to clear.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 04-15-2019 at 10:48 PM. |
04-15-2019, 10:58 PM | #16 |
Re: Hubcap fit
oh great, guess I may have some hubcaps for sale, my tin work isn't that good
04-16-2019, 12:01 AM | #17 |
Re: Hubcap fit
Not a 100% sure, but I think these caps fit over the DANA 60 floater rear axle. (first pic) They are a bit pricey though. I'm running the same caps you are. I got them off of my Brother in laws, '89 K20 Suburban. Since the front caps had the factory hole in it for the locking hubs, I just enlarged them and run them on the rear. I'm good with the look.
04-16-2019, 12:54 AM | #18 | |
Re: Hubcap fit
I ended up buying the period correct caps, as seen on the yellow truck in PepperTreeGarage's post and those clear the Dana 60 full floater hubs. Now, one thing to watch out for, is I believe they made the same style caps for 1/2 ton and 3/4 ton so they "look" alike but they're different sizes.
-Jim 71 Chevrolet C20 94 GMC Yukon 4x4 |
04-16-2019, 01:04 AM | #19 |
Re: Hubcap fit
anyone know where the Eaton H052 measures up to the 14 bolt?
I have a leaf spring D60 4.10 posi in the garage too just in case not ready for my $$ caps to go on just yet but I'm thinkin' a test fit is in order.. thanks for the info folks!
04-16-2019, 01:14 AM | #20 | |
Re: Hubcap fit
04-16-2019, 06:57 AM | #21 |
Re: Hubcap fit
I think the 76-91 hubcaps fit 14-bolt and HO52 but not Dana60. I have run them on HO52s before
The 14-bolt full-floater and HO52 are very similar with 'somewhat' interchanging parts. *You can use a 14-bolt differential in an HO52 if you use the 14-bolt axles shafts, different splines. The 14-bolt shafts are about 3/4" longer and need to be cut. *You can put 14-bolt brakes on an HO52, axle flange-out/complete So you can 'create' an HO52 with 3.73s or 3.42s. And then your hubcaps will fit
04-16-2019, 03:06 PM | #22 | |
Re: Hubcap fit
and I thought both of the caps PepperTreeGarage posted were the same fitment didn't the caps on that longhorn go up into the squares a few years? guess they had a lot of extra space.. so after test fitting both of mine, crisis averted, they fit! thank goodness, hate to have to toss a factory no-spin 4.10 I was planning to pick up a couple of sets of beaters of that later style but guess I'll pass based on what I learned here.. thanks all!
04-16-2019, 04:55 PM | #23 |
Re: Hubcap fit
1970 c20 factory hub caps all orig, color of chevy bow tie based on year 67-72
