Old 04-10-2019, 12:18 PM   #1901
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
These things always come apart easier than they go back together... it’s getting a full inspection, cleanup, and reseal before getting stabbed back in for the (hopefully) last time. Finding lots of little things wrong, so I’m glad I decided to tear into it. Fingers crossed for full function and no leaks
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-10-2019, 03:38 PM   #1902
smbrouss70
smbrouss70's Avatar
Get it taken care of before it hits the road. Smart guy!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-12-2019, 03:11 PM   #1903
mcbassin
Still Learning
mcbassin's Avatar
Awesome progress Chris! digging the stick shift!
Old 04-12-2019, 05:12 PM   #1904
gringoloco
A guy with a truck
gringoloco's Avatar
Well, I don’t know if I’m smart so much as I hate leaks. Prolly should have chosen a different trans for that, as I’m learning that marking territory is part of the Muncie charm, but I’m doing everything I can to make it as dry as possible. Maybe someday I’ll grab a t56 or TKO cheap...
Thanks a lot, I’m just ready to get it stabbed and get to rowin’ gears
On that note, it’s back together with no major parts still laying on the bench, seems to be functioning properly, and is almost ready to stab. Need to torque a new front bearing nut and plumb the hydro throwout first...
-Chris
Old 04-14-2019, 07:37 PM   #1905
gringoloco
A guy with a truck
gringoloco's Avatar
Got the hydro slave all setup and plumbed, then stabbed the tranny back in for the (fingers-crossed) last time. Once it was in place, I got to assembling the entirely too complicated Hurst shift linkages. I am happy to report that it all seems to be working properly and that the throw is actually nice and compact, despite the extra-long shift lever.
-Chris
Old 04-14-2019, 08:01 PM   #1906
gringoloco
A guy with a truck
gringoloco's Avatar
...and fabbed up a mounting bracket for a modified set of ICT Billet coil relocators to bolt to the back of the cylinder heads. These are designed to stack the coils in a row; I rearranged them to suit my needs and to fit the space I have available. Mounted them back where a distributor would be to maintain the small-block ruse
-Chris
Old 04-14-2019, 08:10 PM   #1907
TexasLS1
TexasLS1's Avatar
Holy crap that is awesome
TexasLS1 is offline   Reply With Quote
Old 04-15-2019, 12:02 AM   #1908
cornerstone
cornerstone's Avatar
Yes it is.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 04-15-2019, 12:19 AM   #1909
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by cornerstone View Post
Yes it is.
Thanks dudes! We won’t talk about how many different ways I flipped the coils and brackets around before settling on this setup that just barely fits, but fit it does...
-Chris
Old 04-15-2019, 08:44 PM   #1910
65StreetCruiser
It Is What It Is
65StreetCruiser's Avatar
The end result is all that matters, my friend! Everything that you are doing is spot on!
Kevin
65 Chevy SWB Fleetside Custom Cab (sold, so long old friend it was a fun ride)
68 Chevy SWB Fleetside Custom Cab
68 Camaro convertible
www.louisianaclassictruckclub.com
65StreetCruiser is offline   Reply With Quote
Old 04-15-2019, 11:54 PM   #1911
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, Kevin. Much appreciated. Let’s just see if it actually runs and drives after all of this...
Still chipping away as I poked a couple of 9/16” holes in my nice, shiny valve covers tonight for the PCV system. More to come on this as I finish up with all of the plumbing hopefully tomorrow.
The -6an bulkhead elbow fittings are on the back side of the valve covers, near the firewall where it is starting to get a little crowded. What’s that saying about putting 10 lbs of something in a 5 lb sack?
-Chris
Old 04-16-2019, 02:56 PM   #1912
67chevemall
67chevemall's Avatar
Stellar man. Looks great! good work.
And thanks for taking that bed off, I was worried at first.
3 hours later page 77 all is great
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-16-2019, 03:07 PM   #1913
67chevemall
Please show more of the throw out bearing set up when you can.
Complete awesomeness.
Old 04-17-2019, 01:40 AM   #1914
gringoloco
A guy with a truck
gringoloco's Avatar
Haha, yep, that bed had to go! Thanks for hopping in and appreciate the positive comments
As for the hydro TOB, it is a Ram 78125HD, which reviews well, is rebuildable, and looks and feels like a quality unit. It setup nice and easy using all but one of the provided shims, though I did have to extend the locating pin. No real pictures of it at this point as it is tucked away safely inside the bell housing. Will update here once it’s all bled and (hopefully) functioning properly.
-Chris
Old 04-17-2019, 12:59 PM   #1915
knomadd
knomadd's Avatar
Nice work on the coils. I had that idea floating around in my head but thought it would be too difficult and time consuming, so I moved on. Looks like it worked out great! Maybe I should rethink this...
Do you have some sort of baffle on the valve cover fittings to keep oil from coming out through those fittings?
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-17-2019, 08:49 PM   #1916
gringoloco
A guy with a truck
gringoloco's Avatar
The coils honestly weren’t too big of a deal to do. I think if I took some more time, I could come up with something a little more compact, but this worked well for a modified off-the-shelf solution.
As for the PCV fittings, yes, the “dirty” side will be baffled, using vacuum hose connected to the internal valvecover baffle (pictures of this coming soon). The “clean” side shouldn’t need to be baffled, as it will only be providing fresh air into the crankcase. I also decided to use Earl’s stat-o-seals (rubber o-ringed crush washers) on the fittings to help quell any oil leaks at the bulkhead pass-through.
-Chris
Old 04-18-2019, 06:30 PM   #1917
gringoloco
A guy with a truck
gringoloco's Avatar
Special delivery today, couldn’t help but to go ahead and install the “easy” stuff:
-Chris
Old 04-18-2019, 09:15 PM   #1918
65StreetCruiser
It Is What It Is
Wow!
Kevin
Old 04-18-2019, 09:35 PM   #1919
gringoloco
A guy with a truck
gringoloco's Avatar
Here’s that info/pictures:
-6an bulkhead elbow with 3/8” barb adapters on both ends, then drilled/tapped the valve cover baffle for a 1/8” npt x 3/8” barb elbow, and connected them with a piece of 3/8” silicone hose held on with oetiker clamps. Pretty simple setup that I hope keeps the oil out of the PCV, if not it will just help keep the spark plugs lubricated
-Chris
Old 04-18-2019, 10:47 PM   #1920
sprint_9
sprint_9's Avatar
I like how the coils turned out. You have so much room with that intake, lol, it looks like a dream to work on compared to mine.
I would baffle the clean side as well. Under certain conditions (WOT) it will pull a vacuum on that side. Its a smaller percentage of oil loss through the clean side but it will still make a mess over time.
sprint_9 is offline   Reply With Quote
Old 04-18-2019, 11:42 PM   #1921
rustytruck50
rustytruck50's Avatar
Awesome work!!!
You've got a lot to be proud of!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 04-19-2019, 12:51 PM   #1922
SCOTI
SCOTI's Avatar
That set-up clears everything ok? Hard to tell from my monitor.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-19-2019, 08:08 PM   #1923
gringoloco
A guy with a truck
gringoloco's Avatar
It’s still a bit of a nightmare back there, and I have yet to run the main engine harness, plug wires, or throttle cable...
Good point on the clean side, I may reassess
Originally Posted by rustytruck50 View Post
Awesome work!!!
Thanks a lot, I’ll just be happy to get it running
Yes, it tucks inside the valvecover completely, which is all well above the rockers on the LS. This would not work on an SBC at all
-Chris
Old 04-22-2019, 12:42 AM   #1924
gringoloco
A guy with a truck
gringoloco's Avatar
What I’ve been up to the last few days:
Tore down the original 3-on-the-tree steering column to gut all of the unused everything and take 8.25” of length out of it. This will help put the upper steering joint closer to the firewall, hopefully keeping my angles the way I want them and also clearing everything with the steering shaft.
Ended up deciding to cut my own DD into the end of the shaft as opposed to taking it to a machine shop. Measure twice, cut once, used an angle grinder and finished it off with a set of calipers and a file. Not too bad to do, just a little time consuming. Actually was a little therapeutic (and a little stressful). I will say if you attempt this, do not use the ididit instructions, as their measurements are way off (or I was just to dumb to figure them out)...
Also used a slick little piece from CPP, the “column saver”, which slips into the end of the column and has a bushing and thrust bearings for the shaft to ride on. Made figuring out how to terminate the hacked-off column a no-brainer.
-Chris
Old 04-22-2019, 01:56 AM   #1925
cornerstone
I can relate to your "therapeutic" comment on that kind of work. It's nice to step outside of your day to day thoughts and saturate yourself into something that 99% of people will never even think twice about. My problem is I tend to do this on almost every task I undertake when it comes to my truck project. I admire some of these guys who just knock it out and move onto the next step. Great work as always Chris,
Brian
