Old 06-03-2002, 10:18 AM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Thumbs up The Long and Short of it
What determinds the use of a Long or Short water pump on a big block convertion. I have 72 motor mounts so what pump would I use.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 06-03-2002, 10:35 AM   #2
Pont
I need another Barley Pop
Pont's Avatar
I would think you can use long or short. I have a big block in mine that originally had a short water pump but now has a long water pump. Just make sure you have radiator clearance for the long water pump. It's easier to get brackets and pulleys for the long water pump if that matters to you.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 06-03-2002, 11:01 AM   #3
tom hand
CCRider
tom hand's Avatar
Short was original,so use short if that is important. Long is off 73 up,but is much easier to find and actally better,IMO. On both the big block and the small block when they went to the long water pump they moved all the accessorys in closer,so the setup uses shorter belts,which is much better if you want to build a high reving motor. A long water pump setup works best if you set the motor back about 1.5 inches on a 2WD but you can make it work without doing that.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-03-2002, 11:30 AM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Thumbs up
I have a small block with a short on it. I'd like to convert it over to a long when the pump goes out. The belt to the alternator is much longer and slips easier on the short pump than on the long.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 06-03-2002, 02:36 PM   #5
1970 CST Short Wide
Senior Moment
Thumbs up
Tom
If I set the motor back 1 1/2 inches then I have to move trans mount and cut driveshaft RIGHT? If I dont move it back what problems do I run into?
Thanks for the info
Steve
Pittsburg Ca
94565
Old 06-03-2002, 03:17 PM   #6
tom hand
CCRider
tom hand's Avatar
If you don't move the motor back a stock clutch fan will be very close to the radiator [or actally hit the radiator depending on what thickness radiator you are running] and the fan will be too far in the shroud. So you can use a flex fan with a shorter spacer,[which I do not recommend,they have been know to come apart] or switch to an eletric fan. Moveing the motor back works best and looks completly stock when finished IMO.
Olive Branch MS
