Lowering Your Factory Bench Seat
I found a link to Full Custom Fabrication that sells new seat brackets that lower your seat about 2 inches. Direct bolt on that took less then 30 minutes. One of the best things that I have done to my truck. There is so much more room and the seating position is more comfortable.
https://squareup.com/store/full-custom-fabrication/ |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Lowering Your Factory Bench Seat
These are a must for tall drivers. Thanks for sharing.
Can you still move your seat forward and back with these?
![]() Join Date: Aug 2004
Nice! I book market that, thanks!!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Go to YouTube and check out Whitlock Garage and you will see Robbie , a member here , use those on his 67 GMC . he has a lot of videos but some need to be edited because Im in em .
