Old 04-20-2019, 01:28 PM   #1
skymangs
skymangs's Avatar
700R4 driveshaft solutions
I have a 70 longbed fleet. Right now it has a th350 with a two piece shaft. I’d like to convert it to a 700R4. Does anyone know a shaft that would be compatible? Two piece, 1 piece... Any advice on the appreciated. I don’t want to have to cut and balance if I don’t have to.
skymangs is offline   Reply With Quote
Old 04-20-2019, 02:33 PM   #2
Bigdav160
Bigdav160's Avatar
Re: 700R4 driveshaft solutions
I've cut and re-welded more driveshafts than I care to count. I never had the need to balance.
YMMV
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-20-2019, 07:25 PM   #3
Rick Bollinger
I could be wrong but your driveshaft may bolt right up. The 350 and 700 share the same slip yoke and I believe may even be the same length. My 400 was 2 1/2" shorter than my 700 and a different yoke.
Rick Bollinger is offline   Reply With Quote
Old 04-20-2019, 07:50 PM   #4
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
When I converted my 68 longbed stepside to a 700R4 I had to have a special drive shaft made at a shop.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 04-20-2019, 07:57 PM   #5
kidatheart
kidatheart's Avatar
Did your 68 have a TH350?
kidatheart is offline   Reply With Quote
Old 04-20-2019, 08:08 PM   #6
HIGHWAY BY THE SEA
No.
Old 04-20-2019, 09:59 PM   #7
skymangs
skymangs's Avatar
Thanks all for the replies. I guess I was looking for a common solution. Like the driveshaft from a park avenue wagon is the perfect length, or something.
Old 04-20-2019, 10:11 PM   #8
Rick Bollinger
67-70 trucks came with a 400 trans. I don't believe the th350 came till 71. I may be off on the years but I do know they came much later. Also when you go to set up your 700 consider using bowtie overdrive's TV kit for your carburetor. It's a little more expensive but cheaper than frying a new trans.
Old 04-21-2019, 12:33 AM   #9
tdangle
tdangle's Avatar
The th350 and 200r4 are the same length The th400 and 700r4 are the same length. My 70 C20 came with a TH 350 trans
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 04-21-2019, 06:42 AM   #10
skymangs
skymangs's Avatar
I bought a Loksr TV setup.
Old 04-21-2019, 06:47 AM   #11
skymangs
skymangs's Avatar
Maybe its a 400, IDK, I just assumed it was a 350. Have to look.
Old 04-21-2019, 11:30 AM   #12
Rick Bollinger
I just swapped out my 400 for my new 700r4 and they definitely were not the same length. I cut my driveshaft down 2 3/4". My new yoke was a 1/4" longer than the old one. The 400 trans was 2 1/2" shorter than the 700 r4.
When you go to check your new trans be sure to check your pressures BEFORE you drive it. You can get the directions from the Bowtie overdrive website.
Old 04-21-2019, 11:37 AM   #13
Rick Bollinger
Here is a link to there website. There is a lot of great info here.
http://www.tvmadeez.com/article/index.php
Old 04-28-2019, 05:22 PM   #14
Madkidd007
Madkidd007's Avatar
This is actually quite simple. It depends on which th350 is in it, there is a long and short shaft. But at the end of the day it would have to be shorter if anything and not longer. Have it shortened & balances. Too cheap not to do it and guaranteed a smooth driveline
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 04-28-2019, 05:24 PM   #15
Madkidd007
Madkidd007's Avatar
Thought I’d add this also
Old 04-28-2019, 08:56 PM   #16
Warship2k15
Good info.It looks like if you get lucky and have a long shaft turbo 350 that it will not need the driveshaft modified.
Warship2k15 is offline   Reply With Quote
Old 04-28-2019, 10:59 PM   #17
Lancialonnie
I just had the 350 in my 72 replaced with an early 700R4. The driveshaft needed to be shortened a little bit (either 1 1/2 or 2 1/2 inches, can't remember for sure). I dropped it off at the commercial shop that does lots work on large trucks and they had it ready to go the next day. It sure is nice having overdrive! I have to watch my speed on the freeway now as it is so quiet I don't realize how fast I am going!
Lancialonnie is offline   Reply With Quote
Old 04-29-2019, 07:39 AM   #18
skymangs
skymangs's Avatar
Thanks all. I Feel much more confident about this swap.
