Old 04-24-2019, 09:36 AM   #1
tut69
tut69's Avatar
Pictures needed
I've searched all the wiper threads but still need a good quality picture of a factory wiper motor mounted in a 59 apache. I bought my truck with no wiper motor. Just purchased a motor from LMC but don't know how its mounted. Arms are in place. Any help would be appreciated.
tut69 is offline   Reply With Quote
Old 04-24-2019, 11:10 AM   #2
NeoJuice
Re: Pictures needed
http://www.classiccarsandtools.com/2...-installation/
https://www.stovebolt.com/ubbthreads...=907704&page=1
NeoJuice is offline   Reply With Quote
Old 04-25-2019, 06:56 AM   #3
hogfarm
Re: Pictures needed
From what I recall my 58-59 wiper motor is different than a 55-57.I have one in a box if you need pictures
hogfarm is offline   Reply With Quote
Old 04-25-2019, 08:40 AM   #4
tut69
tut69's Avatar
Re: Pictures needed
Thank you both. Just what I was looking for. Reason I couldn't figure out where motor went is bracket it bolts to is not there. Former owner installed a BelAir dash in the truck and apparently removed the bracket. Guess I have some fabricating to do. Thanks again. Tim
Old 04-25-2019, 08:50 AM   #5
dsraven
Re: Pictures needed
there is also a different bracket for the different motors available. some were vacuum and some electric. if fabbing a bracket I don't suppose it matters though. I think the bump in the firewall area is a bit different for the two as well. I had one of each but they were Canadian models so possibly different anyway.
Old 04-26-2019, 06:49 PM   #6
TXapache
Guest
Posts: n/a
Re: Pictures needed
I installed a new electric wiper motor and if I remember right, I had to use the bracket from the old vacuum unit.
Old 04-26-2019, 07:22 PM   #7
dsraven
Re: Pictures needed
if you gotta fab a bracket why not use a motor assembly from something really common, like a newer style chevy truck? it's only wiring and a bracket that you gotta fab anyway.
Old 04-26-2019, 09:28 PM   #8
paulspickupparts
Re: Pictures needed
58 59 Original Electrip wiper motors attached to a curved bracket in the center part of the dash. It mounted a little bit under the dash and had attached threads so you could just screw the bolts (2) of the original wiper motor bracket into it.
There was also a small threaded bracket on the firewall that also took a bolt from the back bracket of the original wiper motor. You could either fab something or find someone parting a 58 59 to get the bracket you need.
Good luck
paulspickupparts is offline   Reply With Quote
