Old 03-24-2019, 12:48 AM   #351
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: 67 C-30 Dually pickup build.
I seem to have lost the ability to embed YouTube videos. Has it changed from the way it used to be?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-24-2019, 08:49 AM   #352
Getter-Done
Getter-Done's Avatar
Glad you did not sell it and things are looking Brighter for you.
Your Write-up and pictures help me get started with
my dually fenders on a fleet side bed.
I also plan to use Hydro-boost.
I can't help you with the U-tube video's.
I hope someone can.
Looking forward to a video
The early bird gets the worm,
85 Chevy K-20
Old 03-24-2019, 09:35 AM   #353
Last_Paladin
I am glad I asked.
Last_Paladin is offline   Reply With Quote
Old 03-24-2019, 10:24 AM   #354
67_C-30
67_C-30's Avatar
I hope someone can.
Thanks! I took a look at your build - very cool! I'd like to try a crewcab someday, but I'm going to stick with getting this one finished! Hopefully it won't take another 12 years!
If you haven't solid mounted your rear fenders yet, I'd recommend maybe doing it a little differently than I did - or least doing it better than I did. Back then all I had was a crappy flux core welder (plus I'm a much better welder now) and I got some warpage where I welded the tabs on. I'm going to redo mine with '67 stepside fenders, and I'm thinking of gluing the tabs on this time, or buying a spot welder.
Originally Posted by Last_Paladin View Post
I am glad I asked.
I'm glad you did too! The years of working 70-80 hours a week kinda kept me away from here for a long time. I'd lurk occasionally, but it was kinda depressing knowing I had sold most of my trucks, and didn't have time to work on the ones I still had.
My trucks
Old 03-24-2019, 11:48 AM   #355
67_C-30
67_C-30's Avatar
This is the invoice for the simulators that I finally put on the truck. 😂
My trucks
Old 03-24-2019, 12:11 PM   #356
Getter-Done
Your Simulators looks great.
I have not solid mounted my rear step fenders yet.
Which reminds me I needs to update my build thread.
I would like to see pictures when you redo it with the 67 step fenders.
If you can.
That what mine are 67 fenders.
85 Chevy K-20
Old 03-29-2019, 03:34 PM   #357
67_C-30
67_C-30's Avatar
Things got much tighter after the battery box went in. I’ve git to decide which of these setups for the air cleaner I want to go with. This:
My trucks
Old 03-29-2019, 03:35 PM   #358
67_C-30
67_C-30's Avatar
Or this:
My trucks
Old 03-29-2019, 03:49 PM   #359
Sheepdip
Sheepdip's Avatar
I think the first pic w/o the elbow is the cleanest but then again not sure how hot the front of the turbo gets so the elbow might provide some temperature relief.
Sheepdip is offline   Reply With Quote
Old 03-30-2019, 09:46 AM   #360
67_C-30
67_C-30's Avatar
That was my concern as well. I like the way it looks coming straight off the turbo, but I worried about the heat also.
My trucks
Old 03-31-2019, 10:17 PM   #361
67_C-30
67_C-30's Avatar
I posted some of these pics on the main board, but I figured I’d catalog the latest work here on the build thread.
I made spacers to get the alternator positioned correctly and got the correct length bent figured out. I’ll go back and get another one now that I have it right. That will give me twin Hydroboost and alternator belts. The HumVee crank and water pulley caused a lot of alignment issues, but I'm glad to have the extra belts. The single V belts on my CUCV and always squeaking, no matter what I do.
I also figured a way to bend the ‘67 - 68 side molding to wrap around the dually humps. I’m happy with the way that turned out.
My trucks
Old 03-31-2019, 10:26 PM   #362
67_C-30
67_C-30's Avatar
I recorded a couple videos of it running:
https://www.youtube.com/watch?v=A1iHKarTFK0
https://www.youtube.com/watch?v=mo1y5XQn3XY
My trucks
Old 04-02-2019, 12:17 AM   #363
67_C-30
67_C-30's Avatar
I got another belt today, so I have the twin belts to the alternator and Hydroboost pump. I’m hoping this eliminates the dreaded belt squeal associated with the normally V-belt 6.2’s.
My trucks
Old 04-07-2019, 04:54 PM   #364
67_C-30
67_C-30's Avatar
I found out that ‘67 did not have provision for the auxiliary battery tray, but 2 existing holes did line up. I added the 3 additional holes and mounted it.
My trucks
Old 04-28-2019, 11:41 PM   #365
67_C-30
67_C-30's Avatar
Testing to see if I can embed the videos on this thread.
My trucks
Old 04-28-2019, 11:47 PM   #366
3757chevy
3757chevy's Avatar
Originally Posted by 67_C-30 View Post
Yeah it worked.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 04-28-2019, 11:54 PM   #367
67_C-30
67_C-30's Avatar
Originally Posted by 3757chevy View Post
Yeah it worked.
Thanks so much for the tip! I would have never thought of that!
My trucks
Old 04-29-2019, 01:53 AM   #368
3757chevy
3757chevy's Avatar
I learned it here on one of the music posts. Gotta love this site.
MIKE
Old 02-15-2025, 11:52 AM   #369
1972K20
1972K20's Avatar
I know this is an old thread, but how did you wire the fuel shut off at the IP and the high idle solenoid? Also, which hydro-boost setup did you use?
1972K20 is offline   Reply With Quote
