Old 01-24-2019, 12:04 AM   #1
Ethan341
Starter makes clunking noise
After putting a fresh clutch in my truck the starter has been giving me lots of troubles lately...It starts starts occasionally fine but most of the time it makes a terrible clunking noise from the starter. I swapped starters with it from another truck and tried every combination of shims. Don't really know how to describe the noise, its not a dead battery clicking noise but a clunking sound and the engine still turns over just slowly when it happens. After searching around the internet I couldn't find any solutions so anybody have any ideas of what could be happening?
Ethan341 is offline   Reply With Quote
Old 01-24-2019, 12:23 AM   #2
mctattooer
mctattooer's Avatar
Re: Starter makes clunking noise
Are you positive everything tight? Flywheel and clutch and all?just trying to eliminate things is all
mctattooer is offline   Reply With Quote
Old 01-24-2019, 12:41 AM   #3
Ethan341
I am positive I torqued everything to spec and I am sure I would have heard if it was loose when driving it.
Old 01-24-2019, 12:45 AM   #4
geezer#99
geezer#99's Avatar
Is it a block mounted or bellhousing mounted starter?
Old 01-24-2019, 01:08 AM   #5
Ethan341
Block mounted
Old 01-24-2019, 01:19 AM   #6
geezer#99
geezer#99's Avatar
Did you use the correct knurled shoulder starter bolts?
You might need a starter brace.
A thread here on that.
http://67-72chevytrucks.com/vboard/s...d.php?t=492532
Old 01-24-2019, 01:41 AM   #7
Ethan341
I used the correct starter bolts but I don't understand what changed that made it not work as it was working fine before with no brace.
Old 01-24-2019, 02:13 AM   #8
custom10nut
custom10nut's Avatar
Are you absolutely sure you have the right starter. When you say “flywheel” do you mean Flexplate?
I ask this because there are two different starters that will bolt in, but only the one is right.
Does the nose cone have a flat spot on the top, so that the starter clears the bell Housing? If not, you have a round nose cone (from a 73-later) and even though it bolts in tight, it will never line up correctly.
custom10nut is offline   Reply With Quote
Old 01-24-2019, 03:02 AM   #9
kazoocruiser
Re: Clunking noise that is driving me nutz
Not to be funny here, or flame you, but what changed here is that you worked on it. So you installed a problem. I would not be so "positive" you torqued everything to spec.
Without hearing a noise video, or being next to the truck to hear what you are describing as a clunk kind of limits me to offering a guess that you can tear to pieces.
You've tried shimming and alternative starters and all of that effort has not fixed anything. Maybe it is time to look elsewhere.
I think you have a loose flywheel. It's banging back and forth, and when it gets cocked, the starter binds and drags.
It's a heavy clutch pack hanging off the back of the flywheel. it wouldn't take much in the way of loose flywheel bolts to present the problem you are describing here.
kazoocruiser is offline   Reply With Quote
Old 01-24-2019, 05:12 AM   #10
RUN GMC
RUN GMC's Avatar
Check and re-tighten bolts on my installed an high torque starter off an Escalade on my 87 GMC.......after first crank it started clunking noise on next try.....with shield we couldnt tell it didnt totally seat itself.......re-tighten same been good ever since............
RUN GMC is offline   Reply With Quote
Old 01-24-2019, 09:44 PM   #11
El Dorado Jim
sub'd
El Dorado Jim is offline   Reply With Quote
Old 04-30-2019, 12:44 AM   #12
kazoocruiser
Did you ever get this problem sorted out?
1981 C-10 Longbed, 250 (4.1) 2bbl Varajet, THM-350C.
Some of the Build progress:
https://www.youtube.com/channel/UC_W...foLyeDq_WQPNmA
1981 Harley Davidson.
Credentialed, semi-retired A.S.E. technician. If you don't like free advice, Ask Someone Else and pay for it.
