Old 04-30-2019, 11:26 AM   #1
Afirehawk1
66 C10 Suspension Help Needed
Need everyones advice
I have front 2.5” drop spindles and 4” rear drop springs.
Front springs are stock HD for 72 C10 Big Block.
I stuck a 396 in the front. Fits great
Would like to narrow up the tire/fender gap.
I attached couple photos for reference.
Wheels are 245/45/20 on front and back.
Thoughts?
I dont want to screw up the geometry and still be able to have the front end aligned.
Afirehawk1 is offline   Reply With Quote
Old 04-30-2019, 04:48 PM   #2
Afirehawk1
Re: 66 C10 Suspension Help Needed
Anyone?
Old 04-30-2019, 06:42 PM   #3
LVPhotos
LVPhotos's Avatar
Cut 1 coil = 2" drop or go stock non hd and it will squat a lil more
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 04-30-2019, 07:34 PM   #4
Afirehawk1
Hhm
What about 2 inch drop springs?
Old 05-01-2019, 12:42 AM   #5
norcalcap
I have 2-1/2" drop spindles
1" lowered coils
235/60/18 which are about 1/4" taller than your overall height.
4" rear coil drop
norcalcap is offline   Reply With Quote
Old 05-01-2019, 06:18 AM   #6
Afirehawk1
This helps
Old 05-01-2019, 08:44 AM   #7
PGSigns
PGSigns's Avatar
I would put the stock springs back in it and see how it sits. It may also improve the ride over the HD springs and they will be stiffer if you cut a coil.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-01-2019, 02:21 PM   #8
demian5
demian5's Avatar
Originally Posted by Afirehawk1 View Post
Anyone?
Do you have a motor in the truck right now?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-01-2019, 02:29 PM   #9
Afirehawk1
yes sir!!
Old 05-01-2019, 03:43 PM   #10
Johns 66
Johns 66's Avatar
1" lowered coils
4" rear coil drop
I like the look of this...Im using stock springs and spindles so Im wondering if I can go with a lil bigger tire?
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline   Reply With Quote
Old 05-13-2019, 08:07 AM   #11
Afirehawk1
update from what i have figured out.
1. The Moog #6104 front coils (72 C10 with BBC) - Spring rate 1016 lbs; load 2950 lbs install height 10 inches; free height 12.94 inches. this is what i have in the truck right now.
2. The Moog #6082. this is a stock replacement for the 66 C10 regardless of the I6 or SBC V8; Spring rate 722 lbs, load 2406 lbs; install height 10 inches; free height 13.18 inches.
According to Moog, if i change to the original spring it will drop 1 inch.
I was looking at the Speedway Motors drop spring. 2 inch. Spring rate 1100 lbs; free height 11.5 inches.
So the question is if I use this Speedway Motors drop spring, does the "2 inch drop" measure from the original stock height when designed?. if so i would drop 3 inches from the current setup??? when you compare the spring rate, it is higher than the current BBC setup that i have.
i did check 1 think as per Moogs tech line suggestion. I had to be sure when i installed the control arms that they were tightened after the engine was installed not before.
i did raise the center of the front end up so both wheels were hanging; the control arms moved freely downward. However, when i raise 1 side underneath the control arm; there was barely any movement vertically upward. seems the spring is really firm in the upward direction.
would like some thought to this. thanks.
Old 05-13-2019, 10:55 AM   #12
SkinnyG
SkinnyG's Avatar
I have the 1-ton coils in my half-ton squarebody, and I just kept trimming 2" off the pigtail of the spring until it sat where I wanted.
Advantage - when you go lower, you really should be increasing spring rate.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 05-13-2019, 04:00 PM   #13
Afirehawk1
thanks but i really dont want to start cutting coils. any thoughts on what i found.
Old 05-13-2019, 04:37 PM   #14
scoot_mcgrute
I've got 2.5" drop spindles and cut Hotchkis sport springs, 1500lb rate, for about a 5.5" drop total, maybe a touch more. I have a 5.3 in the truck so I cut the springs until I achieved the ride height I was after, tucking tire with a 275/40-18
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 05-13-2019, 08:15 PM   #15
SkinnyG
SkinnyG's Avatar
Why not, if you don't mind my asking?
Old 05-13-2019, 08:31 PM   #16
Afirehawk1
Never done that before
Just prefer buying the correct coil springs that fit the need
Old 05-13-2019, 09:11 PM   #17
SkinnyG
SkinnyG's Avatar
It's not as hard as you might think. And instead of trying a variety of springs in hopes that you get the drop and stiffness you want, you have great success trimming 2" off the end of a coil spring at a time. Not 2" of height, but where the coil wraps around and around and around and then stops - make a mark 2" back from the end and re-cut the end there.
Most lowering springs drop too much and don't go stiff enough.
And, even if you buy the same springs as someone else, your truck might sit exactly different for a variety of reasons. That's why I trim to get what I want, and I like starting with a 1-ton coil spring (those 1000lb'ers). It's really not as stiff as you're fearing. Cutting springs is not the devil. Cutting TOO MUCH off, is.
Old 05-15-2019, 09:20 AM   #18
PGSigns
PGSigns's Avatar
There is no off the shelf spring that you can call the right one till you try it. There are just to many things that can change what you get from what some one else got. The lower price springs may not have the consistent spring rate from coil to coil that a high end spring like Hochkis may have. Then no two trucks are the same and that leads to sometimes having to trim a coil just a bit to get that stance you want for your truck. When you get this truck fully assembled and put some miles on it you may find that it settles in at a lower height than it is now. So making a change now may put you lower than you may want.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 05-16-2019, 07:15 AM   #19
Afirehawk1
So it sounds like there is no difference between a 2 inch drop spring you buy off the shelf vs. cutting the coil the 2 inches off the bottom end.
Old 05-16-2019, 11:23 AM   #20
PGSigns
PGSigns's Avatar
Cutting 2" off the end of the wire will not give you a 2" drop. It will give you about a 1/4" When trimming it the 2" you are measuring along the wire, not cutting the height 2".
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
