Old 05-01-2019, 08:51 AM   #14
sfcharr
Re: Overdrive kick-down switch bracket for straight six
I believe I used GL1 gear oil as recommended by online sources. The relay I have to use is a Standard Motor Products RY12 Relay. I have converted the engine to electronic ignition and have been told this is the relay to use for this setup.
sfcharr is offline   Reply With Quote
250, overdrive, six cylinder
