Old 05-30-2004, 10:59 PM   #1
ryanroo
ryanroo's Avatar
slow starter
hey everyone i have a question. my truck starts great when its cold fires on the first spin almost always. when it gets warmed up even a little the starter acts retarded and slow. is this just the solenoid getting hot? could it be something else and how could i fix it? Thanks
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-30-2004, 11:18 PM   #2
1972C10
1972C10's Avatar
could be timing or a hot solenoid , check your grounds too . hotter engine = more compression so if the ground was weak it woulndt work as well under harder amps
1972C10 is offline   Reply With Quote
Old 05-30-2004, 11:43 PM   #3
Cethern
What was I thinking??
Cethern's Avatar
It could be a bad or a hot solenoid if it's Heat Soak you could add a remote solenoid or a heat shield.
Ceth
72 K5 that needs lots of parts..
71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit...
Cethern is offline   Reply With Quote
Old 05-31-2004, 04:38 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
My also want to check all the connection's and wireing to and from the starter to make sure evrything is clean and tight... I t would not hurt the clean the battery post either if need be.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-31-2004, 08:42 PM   #5
lewi
lewi's Avatar
I had this same thing last week, went to the parts store and they mentioned a portion of the armatuer (sp?) was bad and when I replaced it I haven't had trouble since. fortunatly mine had a warranty from when I replaced it about 2000-3000 miles back, (thats just over a year ago).
1971 Chevy Cheyenne 383/350 LWB 2wd
Built to use, and look good.
lewi is offline   Reply With Quote
