10-14-2018, 08:04 PM | #1 |
project killers twin 10 (gen5 10 speed trans)
welp, here is the latest project, its a super clean 71 c10, it had a good running small block with a 700r4 trans.... but that's not how I roll, so initially the owner and I spoke about doing a LS swap, butttttttt, it turned into a full on build...
-power plant will be a 2018, L86, GEN5 6.2L, with a 10L80e (10 speed trans) - suspension will be ridetech coil overs, front and rear sway bars - brakes will be wilwood 14", aero6 6 piston - Dakota digital, vintage air, etc....... I hope photobucket holds out, and doesn't hold my photos hostage again, but here comes the pics
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 |
10-14-2018, 08:05 PM | #2 |
Re: project killers twin 10 (gen5 10 speed trans)
10-14-2018, 08:10 PM | #3 |
Looking forward to this! Lot of pics please....subbed.
10-14-2018, 08:11 PM | #4 |
and here is the engine, like previously said, its a 6.2L GEN5 engine...
we wanted more power than the stock claims of 420HP, so we added a cam, deleted the DOD, new non-DOD lifters, ARP head bolts, dual valve springs, hardened pushrods, cam phaser limiter, etc...
10-14-2018, 08:23 PM | #5 |
mounting it into my mock-up truck, the 1st problem I ran into was mounting it into the frame, the front of the stock truck style pan hits the cross member, plan A was to notch the cross member to clear the pan, but the stock steering would of been close (if not already touching), so plan B was to modify the stock oil pan, but the oil pick-up tube is pretty much casted into the pan itself.. so we went with a holley oil pan, and it has tons of room.. after the engine would 'fit', I scooted it back towards the firewall, so the headers, and everything else looked to be in a happy spot...
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 Last edited by 68 short step; 10-14-2018 at 08:45 PM. |
10-14-2018, 08:41 PM | #6 |
as many may know these engine don't have provisions for power steering, or power brake booster vacuum outlet...
so to overcome that, we went with holleys front mount accys.. this is a really nice kit that comes with a new water pump housing/mounting bracket for the alt., a/c compressor, and power steering pump...the stock GEN5 water pump and front accy design is rather awkward looking to me anyways, and this kit give it a sleeker more 'traditional' look..as for the powered brakes, we are going with a hydro boost setup, so no need to tap vacuum off the engine, altho factory trucks have a vacuum pump mounted low on the driver side of the engine, that's belt driven..
10-14-2018, 10:03 PM | #7 |
This is where I am with a Gen V 5.3 L83 swap in my 72 c10. My question is how far back to position the engine. By the pictures here it looks like yours is a bit farther back than mine. Am I correct in thinking the size of the blocks are the same?
Very nice work man... -Brian |
10-15-2018, 07:54 PM | #8 | |
11-12-2018, 07:01 PM | #9 |
once test fitted, it was time to get the truck down to the frame and continue on with the mock-up.. so out with the powertrain, and off with the front clip, cab, and bed..
11-12-2018, 07:08 PM | #10 |
continuing on with the mock-up, I removed the factory trans crossmember, and located the new one, then mounted the engine and trans... and did a mock-up of the headers, again, but with the trans this time
11-12-2018, 07:25 PM | #11 |
once satisfied with the engine/ trans fitment, out with everything again, and now was time to make the engine look good..so my go-to color on these swaps is a silver-ish color, but on this one, I mixed some blue (like the cab color) in, and it came out awesome... it has a super mechanical, industrial feel, that somehow matches the exterior blue too.. it came out really cool.. once everything was painted, I went ahead and assembled it all....
11-13-2018, 07:03 PM | #12 |
Tuned in
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
11-13-2018, 10:32 PM | #13 |
Wow. That will be so nice. Was really clean to start also. What I wouldn’t give for a cab that clean I’m just going to ship mine to you now and let you finish my swap!
11-14-2018, 12:06 AM | #14 |
Looks fantastic man. What harness are you using? Are those speed engineering headers? What gears will you be using? With a 29.5 inch tall tire and the final OD ratio of .636, you can get away with a 4:11 and still cruise at 74 mph at 2200 rpm....
Care to expound on the build name? |
11-16-2018, 06:39 PM | #15 | ||
the build name came from this trucks color scheme, I did a another 71 c10 that looked like this truck years ago, and it had a new (at the time) 5.3/4l60e trans, with DOD, etc.. it was cutting edge at the time, as is this truck now.. so its killers twin and its a c10, and a 10 speed, so killers twin 10 seamed fitting..
04-21-2019, 07:17 AM | #16 |
Any updates?
05-05-2019, 02:38 PM | #17 |
Yea interested in the A10 interface and how you manage using that.
