Old 12-03-2011, 09:38 PM   #1
68GMCCamperSpecial
VIN for 1949 truck?
I just bought a 1949 pickup. Where would I find the VIN? I am sure this is an original truck and I think there should be a tag or a number on the cab and the frame, but I have no idea where to look.
Any help would be appreciated.
Thanks.
Jim
68GMCCamperSpecial is offline   Reply With Quote
Old 12-03-2011, 10:47 PM   #2
lazypineapple
lazypineapple's Avatar
Re: VIN for 1949 truck?
on my 52 it is in drivers door jam, front
on a plate, riveted
lazypineapple is offline   Reply With Quote
Old 12-03-2011, 11:13 PM   #3
Root2812
Root2812's Avatar
There were no "VIN" numbers in those days. Depending on the state they were either titled by the engine block number (passenger side of the engine block) or the body number (on a plate in the drivers door jam).
Root2812 is offline   Reply With Quote
Old 12-04-2011, 09:35 AM   #4
68GMCCamperSpecial
Thank you. This one doesn't have a plate on the driver's door, but it was licensed in 1995.
Maybe they used the motor number.
Thanks again.
Jim
Old 12-04-2011, 09:54 AM   #5
50-MO
50-MO's Avatar
There is a plate on the drivers side hinge pillar on my '49 with the vehicle id number, but her in MO it is just like Root2812 said, the generally used the engine block number on the title.
50-MO is offline   Reply With Quote
Old 12-04-2011, 01:48 PM   #6
mr48chev
mr48chev's Avatar
Most states used the engine number up into the early 50's. I've never found anything to back it but I believe that the theory was that in the early days the value of the vehicle was all in the engine and not the body/chassis.
The door tag number served more for info on what equipment was on the truck rather than being a vin number.
If you got a title with the truck the vin should match the stamped number on the pad on the engine by the distributor if it has the original engine. Even if you plan an engine swap I would keep that block if it has the correct vin number that matches the title. I'd get the title in my name and then after an engine swap check on getting an "engine change" designation on the title. That way you won't run into trouble if the truck gets checked for the vin matching the registration somewhere down the road.
mr48chev is online now   Reply With Quote
Old 12-04-2011, 03:09 PM   #7
68GMCCamperSpecial
Thanks for the info.
Here in Georgia, you don't need a title on anything over 14 years old, just a bill of sale.
I will check the motor number and also see if I can track down the tag number from 1995 to see what number was used to buy the tag.
Thanks again.
Jim
Old 12-04-2011, 04:40 PM   #8
mr48chev
mr48chev's Avatar
Check the usual hiding places for an old registration slip. I even found the title to one "no title" vehicle in the glove box in a stack of papers. An old registration slip with the registered name matching the sellers name on the bill of sale would be hitting the jackpot.
Old 12-04-2011, 07:03 PM   #9
RootBeer 6117
RootBeer 6117's Avatar
This should be were the ID tag is this is the one on my 49 on the drivers door jam. There is a number stamped in it. I was able to decode mine on the LMC web site.
RootBeer 6117 is offline   Reply With Quote
Old 12-04-2011, 07:31 PM   #10
68GMCCamperSpecial
I haven't brought it home yet. I will check it out again next Saturday and see if I can find a plate or anything.
Thanks, Guys, for all the info.
Jim
Old 12-05-2011, 01:30 PM   #11
duwem
duwem's Avatar
Mine has a stainless or aluminum palate screwed to the door jam. Number decodes to a 50 chevy 1/2 ton, but the number on the title is an engine number (engine has been replaced now).
Just transfered the title over with no problems.
duwem is offline   Reply With Quote
Old 05-06-2019, 07:38 PM   #12
1949gmcpanel
Im looking to decode my vin# for my 1949 GMC PANEL..where did you find a search engine where i can input the info?
1949gmcpanel is offline   Reply With Quote
Old 05-06-2019, 09:52 PM   #13
Matt_50
You can decode the body serial number. Tells where it was made and which one and the year made. Your tag may have been just screwed on being a 49. Maybe taken off for a fresh paint job st some point? Maybe you'll get lucky any find it in the truck somewhere.
Not sure if panels decode the same but this is the site I used.
http://www.sanjosechevys.org/Tech/te...chevtrucks.htm
1950 Build
Matt_50 is offline   Reply With Quote
Old 05-06-2019, 10:34 PM   #14
MiraclePieCo
MiraclePieCo's Avatar
Stovebolt VIN Buster:
https://www.stovebolt.com/techtips/vin/vinbuster.html
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 05-06-2019, 10:41 PM   #15
1949gmcpanel
Originally Posted by MiraclePieCo View Post
The link doesn't work
This is my vin# for my 1949gmc panel
A228225981
Old 05-07-2019, 08:20 AM   #16
jbarron
The vin is on the motor.
The door tag is just a serial number.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 05-07-2019, 04:56 PM   #17
mr48chev
mr48chev's Avatar
No Chevy truck had an actual "VIN" number until 1954 the first year the feds required actual vin numbers.
The states either used the door post number or the engine number
The one Matt 50 gave decodes the body serial number while this page decodes the engine block serial number.
http://chevy.oldcarmanualproject.com/models/engine.htm
It should be noted that the engine serial number on AD trucks never matches the body serial number There are no "numbers matching" AD trucks. the feds didn't start requiring vin or partial vin on the engine blocks until 1968.
From a Chevelle page:
Beginning January 1, 1968 the federal government requested voluntary compliance of identifying major parts of a motor vehicle by inscribing or affixing an identifying number or symbol on major parts. As far as research has shown, Chevrolet did comply. by stamping a partial VIN on all engine blocks(1). Again, the location on the block may vary between the plants and years but one change was made in 1968. The GM division number ('1' for Chevrolet) was added to the partial VIN. A 1968 version of an Atlanta partial VIN stamping would 18A174373.
My ongoing truck projects:
