Old 05-14-2019, 08:51 PM   #9
Mike C
Mike C's Avatar
Re: Dana 60 question regarding burnouts
What does your SPID say? What sort of tags are on the rear diff? Usually a posi even a worn one does two wheels when you get on it but one possibly power breaking.
In 68 would have had a PowerLock for an LSD which is very well thought of and durable. And they increase pre-load on clutch packs under load. This could explain the two track when power breaking.
The 70-72 diffs would have likely had a TrackLok which is not known for being 100k mile durable. But they are cheap and easy to rebuild.
Added: 50+ year old truck most likely needs a diff fluid change... why does no one ever just pull the cover, inspect their diff and refill with new, clean fluid and appropriate additive? I think this is a weekly new thread anymore.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
