Old 05-15-2019, 06:41 PM   #576
bmxbang
Re: What did you do to your truck today.The 3rd chapter
Me too. Wood for the 68 long step bed
heck yes! That will look amazing.
bmxbang is offline   Reply With Quote
Old 05-15-2019, 07:22 PM   #577
72c20customcamper
72c20customcamper's Avatar
Got the patch panel ready for the bed real easy when a friend has a new computerized brake.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-15-2019, 07:24 PM   #578
72c20customcamper
Using white oak.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-15-2019, 11:00 PM   #579
Steeveedee
Who Changed This?
Steeveedee's Avatar
One of my younger brothers put white oak in the bed of his truck, with stainless steel strips. Everyone joked that the only thing he was going to haul after that was ass. I guess so, what with the 383 stroker and the blower and narrowed Ford 9". I dimly recall that it made it into a magazine. I'll ask one of my nephews if that is true.
~Steven
Simi Valley, CA
Old 05-16-2019, 08:33 AM   #580
72c20customcamper
Using white oak rather than red because it's much more rot resistant when exposed to weather. Not going to be a show bed.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-16-2019, 05:53 PM   #581
72c20customcamper
Major job getting the trailing arm off. Ubolts were frozen in the arm. Had to use heat and a bfh. New bushings and paint. It's back on the truck just to bushed to get another picture
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-16-2019, 08:05 PM   #582
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
My truck has had an incessant whine in the rear end since I bought it. Had it checked and everything is tight and good. Been told some are like that but it annoys the hell out of me. So today I bit the bullet and ordered new rear axles, crown and pinion, bearings, seal set et al and a Detrot Locker TruTrac as the truck has 3:73's and i"m instaling a 700R4 and am getting an original 400 small block which will be replacing , in a few years, the original 90,000 mile 350. I figure with the 700R4 's lower first gear and the 3:73's and a 400+HP small block the TruTrac is a good option.Oh yea the TruTrac cost almost the same as all the other parts combined..
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-16-2019, 08:28 PM   #583
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Still a few components I can add yet, but for the most part "phase 1 of 3" is done.
Failed on the first valve cover gaskets, they were too thin, and I perhaps I blew it expecting the body/paint guy to flatten out the valve covers. Where there's a will there's a way, I ended up flattening the surfaces yesterday. Pillows, hammers and straight edges got her done cleanly. I ordered Moroso gaskets, which are basically 4-5 X the cost. I don't mind spending $45 if it means no leaks. Hopefully they do the trick.
It's all on phase 2 now, which is body and paint, and I'm not doing much of either.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-16-2019, 09:44 PM   #584
72 Super
72 Super's Avatar
Tony, coming along nicely!
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 05-16-2019, 10:26 PM   #585
typerr
Installed the new valve covers & air cleaner I picked up at the Long Beach Collector Car Swap Meet last weekend. Also new plug wires. I think she cleaned up pretty good. Still a few more things to do until I'm happy with my recent purchase. I found the correct alternator mount at CPP so I need to get that installed. I also need to sort out the radiator mounting. I seem to have a 3 row radiator installed in the larger 4 row mounts.
typerr is offline   Reply With Quote
Old 05-16-2019, 11:02 PM   #586
allchevy58
allchevy58's Avatar
Looking good.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 05-17-2019, 03:14 AM   #587
Ganty101
Finally got my new radiator and got it fitted right away. The original brackets didn’t quite fit but longer bolts and some spacers got them to fit good.
Ganty101 is offline   Reply With Quote
Old 05-17-2019, 11:05 AM   #588
OregonNed
OregonNed's Avatar
That looks fantastic!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 05-17-2019, 03:33 PM   #589
71gmcC15
71gmcC15's Avatar
Painted the top of my dash today. Used truck bed liner. Not that I wanted to use it but my black paint when to cap on me so I decided well I got it all masked up I mine as well use the can of bed liner I had laying around. Turned out pritty good. Will see how easy it is to clean in the future. New dash pad on the way.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 05-18-2019, 07:18 PM   #590
FL71C10
Got it running!
https://youtu.be/NVcrKw8zutI
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 05-18-2019, 10:28 PM   #591
Steeveedee
Who Changed This?
Steeveedee's Avatar
Drove it. There was a Buick-Olds-Pontiac meet-and-greet that I started many years ago when I had a hot rod Buick Skylark. I sold my Buick many years ago (the truck is money pit enough!) so another guy started doing it. I went today and got to see some pretty nice old cars. My favorite was a black/black/black '65 GTO with 3 deuces and a 4 speed, and a 389, completely original down to the brake drums, presented by the original owner. I had a '65 GTO, but it was a complete beater.
~Steven
Simi Valley, CA
Old 05-19-2019, 10:27 AM   #592
70 shorty
Where's my beer?
70 shorty's Avatar
Put a new rear u joint in the driveshaft since the old one fell apart leaving me on the side of the road the other day. I decided not to do the front one at the same time, since I have a knack for messing up things that I touch, and it felt fine.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 05-21-2019, 03:29 PM   #593
71CHEVYSHORTBED402
I'm going through withdrawals, a depression and self-doubt because abruptly, there's very little I can do for my truck right now.
I did manage to polish up these Wittek clamps today. They were on the spark arrester/carb. spacer, and withstood the test of time nicely. The power steering reservoir hose has the same clamps.
Tony
Old 05-21-2019, 04:22 PM   #594
70STOVEBOLT
70STOVEBOLT's Avatar
Finished painting the front third of my frame, now I can assemble the front suspension with the disc brake conversion.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 05-22-2019, 07:14 AM   #595
psoucy
psoucy's Avatar
Starting to see some progress on the body, finished getting all the rust off and coated. Did the sandblasting of the cab myself, won't do that again. I sent the rest out to the sandblasters, he's going to epoxy prime for me. Can't wait to start putting this baby back together.
psoucy is offline   Reply With Quote
Old 05-22-2019, 01:59 PM   #596
Knight72
Rebuilt the rear drums. Ended up having to reuse some old springs. New kit wasn't right. And test painted a spare rallye and eyeballed it to see if I'll like the look. Gonna rock these with white letters. Gotta figure out how to secure the caps though
72 C10 lwb fleetside aka Big Rhonda.
Still plugging away.
Build thread:
http://67-72chevytrucks.com/vboard/s...42#post8247142
Knight72 is offline   Reply With Quote
Old 05-22-2019, 05:49 PM   #597
Already Gone
Didn't actually do anything to the truck today but Fed Ex and Purolator stopped by with some goodies for it, which will be installed within a few weeks.
Old 05-22-2019, 05:51 PM   #598
72c20customcamper
Welded in the patch panel .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-22-2019, 09:57 PM   #599
Astro-Balls
Astro-Balls's Avatar
Heater Core and AC cleanup, New Fan Switch and Resistor, Seals etc...
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 05-22-2019, 10:03 PM   #600
Astro-Balls
Thats a great idea, No Glare either. looks great.
