Old 05-08-2019, 11:20 PM   #1
westong
1972 gmc dana 44 front axle info
I did a search and did not find a definitive answer for my issue so i figured i were ould ask as as someone on here knows the answer. My driver side/long side on my 72 gmc 1/2 ton front axle dana 44 is broke and needs replaced. My cousin who lives a few hours away has a pile of chevy axles and will be coming thru my town on Sunday and will bring me what i need. I have not pulled my front end apart yet to get the spline and axle length so he can measure/count and bring me the right part. Does any one by chance have that info handy? Pic of my wheels/tires and cap for your pleasure.
westong is offline   Reply With Quote
Old 05-09-2019, 01:15 AM   #2
kwmech
Re: 1972 gmc dana 44 front axle info
All the Chevy 44 stuff is the same aside from the smaller early u-joint. 1972 should have the larger 2nd design. But any complete assy up to 77 will fit
Old 05-18-2019, 08:20 AM   #3
Check the stamping on the long axle tube for BOM. '72 had a 1st and 2nd design. If you have the second design you can use the 'post-72 Dana 44 parts. If you post that number I can check my parts book for which design you have.
Make sure you replace your spindle bearings. They are often the culprit.
