Re: 72 rear frame/bumper help
This is a 72 Blazer frame with a pickup bumper bolted to it. Just ignore the bumper and the two bolts. What you will see is an un-cut rear frame with the end tab bent out. If that tab was @ 90 degrees to the frame it would be correct. I just have to bend it back. You can see the rear frame body mount hole as reference. Hope that helps. Jeff |
| Bookmarks |
