Old 05-31-2004, 11:23 PM   #1
screwballl
Tonawanda 454
screwballl's Avatar
Angry Odd problem w/ 76GMC c15
ok, not sure whats going on here but for some reason, after the truck has warmed up (10-15 minutes minimum), if i shut it off and leave it for 1/2 to 4 hours and try to start it, most of the time it wont start as if it was flooded. it is all stock 350 with Rochester 4bbl... its real annoying when i come home from work on my lunch break and cant get it started (and being late getting back to work). Sucks having to drive the wifes Nisshat Pathloser...
any suggestions or similar problems/solutions?
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 06-01-2004, 11:27 AM   #2
screwballl
Tonawanda 454
screwballl's Avatar
i talked with a mechanic friend of mine and he didn't know exactly what it could be but said its probably ignition related although i don't see how since it turns over, just doesn't start. He suggested maybe the ignition coil and fuel filter/pump. it does seem to be getting a spark so the coil might be out of question....
this is just so confusing.. I've checked over several things and everything seems to be working fine...
Old 06-01-2004, 10:41 PM   #3
SanitysBane
maybe the floats are sticking open
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 06-01-2004, 11:17 PM   #4
screwballl
Tonawanda 454
screwballl's Avatar
forgive my n00b question but would that mean a new carb or just some carb cleaner or what... im a computer tech, not a truck tech lol
Old 06-01-2004, 11:20 PM   #5
SanitysBane
it would mean pulling the carb apart and while your at it probally rebuild it...might be better to get a new carb, and the floats are internal to the carb, im not shure how to get to them on a stock carb...
'88 K5 Blazer
Old 06-02-2004, 07:48 AM   #6
screwballl
Tonawanda 454
screwballl's Avatar
ok i have been thinking of replacing it anyways, been looking for a decent rebuilt Edelbrock 650cfm (the one that my mechanic friend strongly suggests)
Old 06-02-2004, 11:27 PM   #7
SanitysBane
if that doesn't work i have no clue
'88 K5 Blazer
Old 06-02-2004, 11:30 PM   #8
1FaastC10
1FaastC10's Avatar
sounds more ignition related to me, especially if you have no real problems with it once its running.
1FaastC10 is offline   Reply With Quote
Old 06-03-2004, 07:52 AM   #9
screwballl
Tonawanda 454
screwballl's Avatar
it still turns over no problem... i can sit there cranking it for 20 minutes no problem... so i am really wondering if it might be the coil, ignition module thing or the carb.....
Old 06-03-2004, 06:05 PM   #10
76bonanza
76bonanza's Avatar
Does your gas line/tank vent well? I have heard of vapor lock in the fuel line with a warm motor keeping it from starting. From my understanding it comes from not venting your fuel system well.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 06-03-2004, 11:46 PM   #11
screwballl
Tonawanda 454
screwballl's Avatar
it is stock everything so i am not sure....
Old 06-07-2004, 06:49 PM   #12
screwballl
Tonawanda 454
screwballl's Avatar
if the ventilation is all it needs, what would be the easiest way to take care of that?
Old 06-07-2004, 06:51 PM   #13
76bonanza
76bonanza's Avatar
Well mine has a vapor line going from pump to tank. Some remove these with aftermarket pumps and use vent caps on the gas tank cap or so I have heard. Had a fried just cut his and leave it and he had problem like yours.
1968 c10
lowered 3" 4"
Old 06-25-2004, 08:06 AM   #14
screwballl
Tonawanda 454
screwballl's Avatar
ive tried some calling around to different places and i got different answeres from different shops. one said oil pump is on the verge of going out, another said carb, another said "its normal when the piston rings are shot", even a good friends of mine's dad whos retired military master mechanic didnt know without actually taking a look at it...
