Old 05-21-2019, 12:18 AM   #1
SavageC20
SavageC20's Avatar
71-72 C20 Front Bake Hoses (Again)
After searching everywhere for brake hoses for my 72 C20 I still have not found a set that fits into the stock tabs on the frame. Does anyone on here make custom hoses that would work for this application? Or does anyone know of brake hoses from another vehicle that will work in this application? I have been unable to find a local shop that is able to make these hoses.
Below is a picture of the problem. The retaining clip groove does not protrude far enough into the bracket to slide the clip in.
I really don't want to modify these hoses by cutting a new groove in the fitting for safety reasons.
SavageC20 is offline   Reply With Quote
Old 05-21-2019, 12:02 PM   #2
PepperTreeGarage
PepperTreeGarage's Avatar
Re: 71-72 C20 Front Bake Hoses (Again)
I carefully measured and then cut new slots. But since I'm lowered the hose length is a little on the short side and just a bit tight. I'm going to have custom ones made approx. an inch or so longer.
PepperTreeGarage is offline   Reply With Quote
Old 05-21-2019, 01:38 PM   #3
Jcfcamaro
Jcfcamaro's Avatar
Call Karps power brake. They are making me custom hoses for my lifted 72 k10. You have your choice of factory rubber style or braided stainless.
Jcfcamaro is offline   Reply With Quote
Old 05-25-2019, 12:37 PM   #4
woodz1972
I ended up using brake hoses for a 69' Camaro and they worked great.
woodz1972 is offline   Reply With Quote
Old 05-25-2019, 08:21 PM   #5
mikecaddy500
mikecaddy500's Avatar
Parker Brake Grand rapids, Mi. (616) 243-7769
mikecaddy500 is offline   Reply With Quote
Old 05-25-2019, 09:02 PM   #6
SavageC20
SavageC20's Avatar
I found a hydraulic shop that is somewhat local to me that makes brake lines. They gave me an assortment of fittings to take home and try on the truck. None of them ended up fitting right so I resorted to cutting a groove in them with a Dremel to make it work. The shop carries brake quip fittings, the banjo fitting part numbers are hfb158 and 159. However, the shop was unable to source the banjo fittings that connect to the caliper because they have apparently been discontinued. So I resorted to giving my repro lines from GMCPauls to them and they are going to cut the banjo fittings off and solder them to new "lifesaver" fittings.
This was way more work than I thought I would be, but I should have a truck that stops on a dime when its all over. I'll post pictures of the finished products once I get the lines back from the shop and install them.
Old 05-29-2019, 11:51 PM   #7
SavageC20
SavageC20's Avatar
The hydraulic shop ended up burning through the banjo fittings when trying to fit them to the lifesavers. I ended up just using a random banjo fitting off the shelf and had the lines made up 1 inch longer than stock. Had to grind down the raised area on the drivers side caliper a bit to get the fitting to sit flush. Ended up working out well. Here are the new lines.
Old 05-30-2019, 08:02 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Is it just the angle of the picture, or does that line make a tight turn going to the caliper? Or is it my eyes? I had surgery on my foot this morning and I'm a bit cross-eyed, yet.
~Steven
Simi Valley, CA
Old 05-30-2019, 08:20 PM   #9
samkost
samkost's Avatar
Flipped for you.
samkost is offline   Reply With Quote
Old 05-30-2019, 10:43 PM   #10
SavageC20
SavageC20's Avatar
Thanks for rotating. Here's another shot.
The bend isn't too bad
Old 05-30-2019, 11:32 PM   #11
basketcase
basketcase's Avatar
Was that on a lowered truck? My '69 with C/10 stock brake hoses is tight on the left side with 2" lower springs. I could use an inch or more to give it some slack.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 05-31-2019, 11:01 AM   #12
Steeveedee
Who Changed This?
Steeveedee's Avatar
Thumbs up Re: 71-72 C20 Front Bake Hoses (Again)
Much better!
~Steven
Simi Valley, CA
