05-17-2019, 08:35 AM | #1 |
'75-'80 Custom Deluxe emblem placement
Can anyone give me the measurements for locating the front fender emblem? Previous owner took them off and filled in the holes. Fenders look naked without them. Thanks!
05-20-2019, 02:57 PM | #2 |
Re: '75-'80 Custom Deluxe emblem placement
The first thing I would do is look behind the fender @ the hinges to see if you can see how they filled the holes in. Or you can take out the inner fender see better you may just have to pop out the filler. Unless they welded them up.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
05-25-2019, 03:00 PM | #3 |
1980 C30, driver's side
A few Fords and a couple of Chevys |
05-25-2019, 08:16 PM | #4 |
Thank you Fordguy40! This helps a lot. Really appreciate it!
05-25-2019, 09:30 PM | #5 |
You bet!
