Old 05-27-2019, 06:56 PM   #1
jlampka
Cab Rust Areas
Hello all - posted a few pictures of my cab where rust is located on my 1971 Chevy C20 that I purchased from San Diego 6 years ago. Who said SoCal trucks are rust free? LOL!
I have a cracked windshield so I hesitate to replace it because of the rust areas in the attached photos. I don't know if the rot is in the windshield seal area and if the windshield perimeter is weakened from the inside rust shown.
Looking for comments from individuals who repaired similar rust area on the cab.
Thank you!
jlampka is offline   Reply With Quote
Old 05-27-2019, 07:39 PM   #2
jlampka
Cab Rust Areas
Thank you!
Old 05-27-2019, 08:07 PM   #3
tristan
Re: Cab Rust Areas
Wish I could help you with the rust but I can't. However, as a native NTer I just have to say hello. Give them my best regards at Galassi's and Platters.
tristan is offline   Reply With Quote
Old 05-27-2019, 08:47 PM   #4
jlampka
Re: Cab Rust Areas
Howdy to Tristan!
Old 05-27-2019, 09:39 PM   #5
72 tigger
72 tigger's Avatar
Re: Cab Rust Areas
Sorry to see that- looks pretty bad. I would guess the windshield flange is really weak
72 tigger is offline   Reply With Quote
Old 05-27-2019, 10:21 PM   #6
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Cab Rust Areas
I would think either a roof replacement, or cab replacement depending on the rest of the truck. I think you will be opening a can of worms if you remove the windshield.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 05-27-2019, 11:10 PM   #7
Peanut74
Re: Cab Rust Areas
If yours is like mine the seal area is fine. The only way to know for sure is to pull the windshield out and while it is out repair the rotted areas. You might wire brush the inside areas and see just how far the rot goes before pulling the windshield.
Peanut74 is offline   Reply With Quote
Old 05-28-2019, 01:27 AM   #8
Average Joe
Average Joe's Avatar
Re: Cab Rust Areas
That dont look pretty. Pretty sure you are gonna open a can of worms when you pull out the old windshield. There are a lot of ways to "fix" this. Probably the right way would be to remove the outer truck roof and replace. Then patch in the inner with new metal. I have seen others treat the rust and apply fiberglass filler. Obviously not a long term or structural fix though. Either way, good luck!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 05-28-2019, 04:53 PM   #9
Grumpy old man
Grumpy old man's Avatar
Re: Cab Rust Areas
There's a reason it was painted without pulling the windshield . if the inner and outer cab look that bad the pilars and rockers are gone also . Your looking at cab replacement it's just not worth repairing all that rust and it's going to be a lot worse when you pull that windshield considering only 1/2 of what's bad is reproduced sheet metal . Sell it and buy another . Never buy a truck with shiny paint on the rubber windshield gaskets .
