Old 05-28-2019, 05:49 PM   #1
cj847
cj847's Avatar
Re: 3 speed overdrive
Originally Posted by CRUZN66 View Post
Here’s where I put mine, just make sure where you route it so that it doesn’t make any sharp angles or kinks.
I thought the overdrives were electric, but what you have appears to be some kind of cable??
cj847 is offline   Reply With Quote
Old 05-28-2019, 06:10 PM   #2
dschmit
Thanks CRUZN66 that's where I was kinda thinking to put it. Do you happen to have a picture or the engine side?
dschmit is offline   Reply With Quote
Old 05-29-2019, 02:27 AM   #3
CRUZN66
CRUZN66's Avatar
It’s hard to see from the engine compartment, because it’s behind the left head. I’ll see if I can get a picture tomorrow, however here’s another picture of the interior and if you zoom in you can see it where it goes past the back of the gauges and through the firewall just above the gas pedal and carpet towards the hump.
CRUZN66 is offline   Reply With Quote
Old 05-29-2019, 04:43 PM   #4
CRUZN66
CRUZN66's Avatar
Here’s a better picture of the inside of the cable and a picture of the cable from the engine compartment however you can barely see the cable about in the center go down by the oil filter under the corner of the engine & bell housing.
Old 05-29-2019, 11:49 PM   #5
Railroader
Railroader's Avatar
When I installed the O/D in my 63 I put the cable mount below dash just right of steering column. However, I have NEVER used it. If I was doing it again, I wouldn't put it in.
Railroader is offline   Reply With Quote
Old 05-29-2019, 02:12 AM   #6
CRUZN66
CRUZN66's Avatar
When the cable is pulled out it locks out the overdrive so the transmission isn’t free wheeling any longer.
