Re: Dakota Digital Tachometer wiring?
Thanks. I checked and there’s a tach connection on the distributor. So I just run a wire from that through the firewall?
I still can’t work out the Shifter module setup but at least I can sort the tach. |
Follow the provided directions on setting up the shifter module. There is a set up procedure to get it to sync with your trans .
