03-10-2019, 06:14 PM | #76 |
Re: New project : 72 Suburban
Front lower section of right rear quarter fitted and tacked as well as the 3rd door rocker. If time permits this week I might get it welded in place one evening.
03-10-2019, 06:46 PM | #77 |
Looks great burn it in
03-20-2019, 06:43 PM | #78 |
3D analog digital dash from Itellitronix came today
03-24-2019, 01:40 AM | #79 |
Finished up the passenger side panel replacement
03-24-2019, 01:52 AM | #80 |
Started working on the new fuel tank. Welded a portion of the original neck to the new tank. Once the new electric fuel pump and sending unit are installed in the tank, wired and plumbed it will be ready
03-24-2019, 06:12 AM | #81 |
What did you go with for fuel pump?
03-24-2019, 08:06 AM | #82 |
03-24-2019, 09:49 PM | #83 |
DND Trucks
Who makes the tank and why is it returnless? Are you running FI or carb?
03-26-2019, 07:09 PM | #84 |
Bought the tank from LMC. The fuel pump itself is returnless ( Holley retrofit module ) some friends of mine at a shop recommended the pump. That is what they use on most of their builds, just seems to be less hassle I guess. I'm running a 4150 style intake with injectors and a throttle body
03-31-2019, 07:54 AM | #85 |
Finished assembling the fuel tank yesterday and installed it into the Suburban. Today will probably concentrate on plumbing the intake and running the fuel line. Hopefully in a couple of weekends the wiring will be complete as well and the motor will be ready to fire up for the first time
03-31-2019, 05:14 PM | #86 | |
The Older Generation
Looks good! LockDoc
04-13-2019, 09:19 PM | #87 |
What motor mounts did you use, i'm doing a 6.0l ls in a 72 2wd blazer with a 700r4 trans and i am having issues with heigth of trans with trailing arm crossmember
04-14-2019, 03:59 PM | #88 |
04-14-2019, 04:09 PM | #89 |
Getting closer to start up. Radiator support , radiator, and some plumbing completed. Waiting on some odds and end parts to come in so the motor and trans can be buttoned up and I can move on to the wiring
04-22-2019, 08:50 PM | #90 |
Great progress. Looks great!!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
05-01-2019, 07:47 PM | #91 |
Been working on the wiring for the Suburban (when time permits) I have the 3D analog digital dash from Intelletronix put together and powered up the lights with a 9 volt battery. should be a nice piece once it is installed in the dash itself
05-04-2019, 10:37 PM | #92 | |
Wow! That baby really shows up. Will the dash light dimmer work with it? LockDoc
05-05-2019, 07:32 PM | #93 |
05-05-2019, 07:52 PM | #94 | |
OK, That's what the newer cars do. LockDoc
05-08-2019, 03:44 PM | #95 |
You have put some serious work into that old girl! Looks good!
What scares me is that I am looking at duplicating your efforts on one I am looking at as far as all that rust repair. I guess the rust is in the "usual" places on these....pretty much anywhere water can find a place to pool. |
05-12-2019, 06:11 PM | #96 |
Today Dad and I were continuing on the wiring on the Suburban and made an amazing discovery. Powered up the wiring harness for the rear AC unit and the fans came on, all 3 speeds and the small cone shaped interior light underneath the unit is operational and working. Good day in the garage today!
05-12-2019, 09:04 PM | #97 | |
06-01-2019, 10:49 PM | #98 |
Wiring is just about finished on the Suburban. Last week Dad and I took a few days and built the exhaust system for it, came out pretty good. In the process of building a homemade oil primer for the LS. Hopefully sometime next weekend I will fire it up for the first time. Cant wait to hear it run!
06-03-2019, 04:01 PM | #99 | |
06-09-2019, 07:06 PM | #100 |
Started the Suburban up for the first time this afternoon. The 402 stroker LS sounds pretty good ! When I get back into town on Friday we are going to go through the gears in the trans to make sure it is good to go then Saturday start hanging the front clip on it ... Getting excited ! Cant wait to drive it for the first time !!!
