Old 06-03-2019, 07:57 PM   #1
hunter1123
Manual to hydraulic clutch questions
Does anyone know if there is a year of Chevrolet pickup with a hydraulic clutch master cylinder that will fit correctly with the 1970 k10 manual clutch linkage?
Thank you
hunter1123 is offline   Reply With Quote
Old 06-04-2019, 08:32 AM   #2
clay68c10
clay68c10's Avatar
Re: Manual to hydraulic clutch questions
Some square body trucks had hydro clutch setups, maybe mid to late 80s.
You might ask over on the 73-87 side
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-04-2019, 11:30 AM   #3
hunter1123
Okay thank you!
Old 06-04-2019, 10:24 PM   #4
57taskforce
All about them K’s
57taskforce's Avatar
I used captainfab’s setup. It works great. 85+ square body have them But it will take some engineering to get the master to work with the pedal. You can see captainfab’s stuff in my build thread in the link in my signature. Start at post#135 and continue into page 7 for more pictures. You can buy his master cylinder kit from the parts board and I used an 80s aluminum hydraulic clutch bellhousing and slave. The clutch, pressure and throw out are for a 72K20. The line is metric to 3/16 inverted flare to JIC braided flex hose.
Tyler
Old 06-05-2019, 07:58 AM   #5
hunter1123
Old 06-05-2019, 07:59 AM   #6
hunter1123
Okay cool thanks for the help!
