Old 06-04-2019, 09:37 PM   #1
dmjlambert
dmjlambert's Avatar
Question remove needle from zerk fitting
OK folks, I need somebody smart to tell me how it's done, please. I got out my new grease gun, loaded it with a cartridge, bled the air and squirt some grease in a trash can. I thought "that's great, I'm all set." I put a needle that has a zerk on it onto the grease gun hose, and used it to inject some grease. Worked fine.
Now I can't get the needle off, no way no how. Is there a trick to this?
I have tried putting the needle zerk in a vise and pulling, twisting, jerking, flipping, finessing, prying with screwdrivers, and as a last resort, cussing. I loosened the fitting on the grease gun hose end, which according to all I've read, watched videos of, and experienced in my years, is supposed to make it let go of a zerk. The zerk swivels around on the fitting just fine and just like I expect. I completely removed the fitting from the hose now. I hope you guys just tell me something stupid I've done and I can have a V8 moment.
Old 06-04-2019, 09:51 PM   #2
BCOWANWHEELS
Re: remove needle from zerk fitting
It unscrews. This will let the tension onthe tiny jaws inside relax.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 06-04-2019, 10:04 PM   #3
dmjlambert
dmjlambert's Avatar
Thank you for the education. It worked.
Old 06-04-2019, 10:43 PM   #4
BCOWANWHEELS
Glad to help. Tighten it up just enough to get light holding pressure on zerk.
Old 06-05-2019, 11:27 AM   #5
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
You ain't the first person to have that problem, believe me!
~Steven
Simi Valley, CA
Old 06-05-2019, 11:45 AM   #6
demian5
demian5's Avatar
I would never admit that this happens to me every time I use my grease gun...
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 06-05-2019, 06:33 PM   #7
Astro-Balls
Astro-Balls's Avatar
You're not holding your tongue right..
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 06-05-2019, 07:57 PM   #8
dmjlambert
dmjlambert's Avatar
No, I'm pretty sure I had that part right.
fitting, grease gun, inject, needle, zerk
