Old 06-05-2019, 04:41 PM   #1
howell57
72 radiator
What is the tallest radiator that will fit in a 72 C10?
howell57 is offline   Reply With Quote
Old 06-05-2019, 06:04 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 72 radiator
If you have a V-8 already, you have the tallest radiator available already, which is, I believe, 19" tall. You would have to buy a later model radiator core support to get a taller radiator installed. You can go to as many as 4 rows in brass.
~Steven
Simi Valley, CA
Old 06-05-2019, 07:10 PM   #3
howell57
Re: 72 radiator
Putting a new L83 in my 72 and have managed to get a lot of OEM parts from donor truck which fell off a rail car with 2 miles on it. It was my thought to get the radiator and fan set up since the fans are a PWM controlled setup. I think the radiator is 17.5" high and 33-34" wide. I can rework the core support in order to install this unit.
Was wondering if anyone else had tried this???
Old 06-05-2019, 09:29 PM   #4
cornerstone
cornerstone's Avatar
Re: 72 radiator
I’m thinking about doing the same thing since that radiator and fan are designed for this engine. My L83 from a Silverado is the first year (2014) so I can’t say that your cooling system is the exact same as mine but, the dimensions are bigger than you estimated. Here are pics of the radiator , trans cooler and fans. Considerably wider than my 72’ for sure.... 39.5 wide and 17.5 tall. Plus, I really don’t want to drop another GRAND just on a cooling system (Entropy). I know they are “works of art” and real purdy but I can’t see it while I’m driving!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 06-05-2019, 10:05 PM   #5
howell57
Re: 72 radiator
Through the auto yard I got my engine from, they want $550 for the rad and fan setup off of a 2019 Silverado. I got the OEM fuel pump and ecu. I got all the fuel lines for a shipping charge. Got the OEM cold air intake and filter box. Only thing I need to figure out is the fuel tank that will accept the pump. Not looking for show quality, those years are behind me. Let me know how you deal with that 39.5".
Old 06-06-2019, 12:54 AM   #6
cornerstone
Re: 72 radiator
I would be interested in seeing how you installed your cold air intake and filter box. I have those components but just assumed I would need to get something aftermarket, but I'd rather stay as much GM as possible. In regard to your fuel pump fitment into the tank, what tank are you using? Have you checked out Swaptime on Youtube? Mitch has done many L83 swaps and is really helpful. He has several videos related to fuel pump / tank / and fuel line solutions, and seems to make these kind of problems easy to solve.
Brian
Old 06-06-2019, 09:30 AM   #7
howell57
Re: 72 radiator
Mitch did my harness and added the wiring for the OEM pump. I'm looking at two tanks, one is a Suburban (38 gal) and the other is just a rectangular tank for a 72. The connections on the pump sit 2" above the seat for the pump, so I have to cut and recess one corner of the tank 2". I have a guy in town that does great welding.
Old 06-06-2019, 05:58 PM   #8
howell57
Re: 72 radiator
Took a long look at the radiator core support and to me, it seems like the unit could sit over the two longitudinal support members. Their spacing is 41.5" outside to outside and 36" inside to inside if you wanted to put in the same cavity the old one was in.
Why couldn't you just lay the unit on those support pieces? I put my motor mounts in so that the engine would be forward as much as possible, but could easily move them to the backward position. Trans hump if necessary is not big deal. Almost going to pull the trigger and order the OEM rad and fan assembly.
Thought???
Old 06-07-2019, 10:00 AM   #9
cornerstone
Re: 72 radiator
I’ll set the assembly on the core support and shoot a bunch of pics to give us both a better idea.
Brian
Old 06-07-2019, 10:07 AM   #10
howell57
Re: 72 radiator
I belong to four C10 Facebook forums and one posting of his engine bay shows what I was explaining. He sat the assembly on top of the vertical support pieces.
Old 06-07-2019, 10:30 AM   #11
cornerstone
Re: 72 radiator
Cool. I only know of two Facebook groups ... what are the one you know of?
Brian
Old 06-07-2019, 11:37 AM   #12
howell57
Re: 72 radiator
C10 parts for sale C10 builds and info C/10 club California C10 addiction(pro performance) C/10 club California
I'm sure there are more, you just have to go and put in "C10" in the Facebook search and lots will come up. The above are just the ones I watch plus SWAPTIMEUSA.COM
