Old 06-05-2019, 04:31 PM   #1
57larry
Brake Pedal Pad Install Question
how do you install that little rubber pedal pad on the pedal. I tried several times but can't fit it on. Any tricks to installing? thanks, Larry
57larry is offline   Reply With Quote
Old 06-05-2019, 04:57 PM   #2
RustyPile
RustyPile's Avatar
Re: Brake Pedal Pad Install Question
A kittke WD-40 to slick things up a little and, with the help of a cotterkey extractor tool to roll the lip of the pad over the pedal and it's done..
http://www.searshometownstores.com/p...iABEgKbiPD_BwE
RustyPile is offline   Reply With Quote
Old 06-05-2019, 05:03 PM   #3
RustyPile
RustyPile's Avatar
I guess the "edit" button is broken.. In case you're wondering "kittke" is Klingon for "little"..
Old 06-05-2019, 05:19 PM   #4
57larry
good idea, thanks, Larry
Old 06-05-2019, 06:01 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
They get a lot of pressure from a foot being pushed on them, so they are really tight so as to not slip off at the wrong moment. I did mine without any lube starting at the bottom, since they taper out as they go up. It wasn't any fun. I think that the factory uses the same lube that is used to mount tires on the rim.
~Steven
Simi Valley, CA
Old 06-05-2019, 06:30 PM   #6
Astro-Balls
Astro-Balls's Avatar
If you have the stainless trim that goes on the pedals, Install those last, straighten the folded tabs before pressing over the rubber pedals.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
