Old 06-04-2019, 11:54 AM   #1
78GMC_truck
Stock and drop formula, wheel vintiques?
So according the Squarebody syndicate formula on their website they suggest you custom order the 62 series steels wheels from Wheel Vintiques. Front wheels 15x8 with a 4" backspace and the rears 15x10 with a 5" backspace.
I called Wheel Vintiques yesterday to order these wheels with the custom backspace. They said that they can only do the 15x8 in 4 1/4" backspace and NOT the 4". They did mention that if I ordered the wheel inverse (flipped around) that only then they could get the backspace to 4". But that would give a slightly different lip appearance.
My question is what kind of fitment issues would I have if I ordered the 4 1/4" backspace on the 15x8 (front wheels)?
Is there any other company that makes the O.E looking steels wheels that I can custom order the backspace and still be able to install the poverty caps/dog dishes.
thank you for your time.
78GMC_truck is offline   Reply With Quote
Old 06-04-2019, 02:01 PM   #2
SCOTI
SCOTI's Avatar
Re: Stock and drop formula, wheel vintiques?
The 4.25" BS will work as well. There could be a possible interference issue @ the lower control arm when using some drop spindles. It's a simple (& common) fix that requires trimming the lip back (also referred as 'trimming the rain gutter') between the BJ & shock mount tab area.
Also, ordering a 'custom' back space is (was?) $25 extra per wheel.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-04-2019, 02:24 PM   #3
78GMC_truck
Hey thanks man! Yes its 25 extra per wheel but the guy said they couldn't make it with the 4" backspace. The lowest he would go is 4.25". I guess I'll just order them anyways. Thanks
Old 06-04-2019, 02:27 PM   #4
SCOTI
SCOTI's Avatar
They'll work fine. Just check for the clearance issue mentioned (usually occurs near full lock/turn) & tweak the a-arms if necessary.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-04-2019, 03:25 PM   #5
Mathew21
Mathew21's Avatar
When I ordered Wheel Vintiques Wheels the price was cheaper through Summit racing then it was through Wheel Vintiques. That was a few years ago but it worth be worth checking. Summit also has free shipping on orders above $99.00.
https://www.summitracing.com/search/...cending&page=1
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 06-04-2019, 04:30 PM   #6
SCOTI
SCOTI's Avatar
Last ones I ordered were also cheaper through Summit but you can't get 'custom' BS; only standard. Might be different now so it's worth asking.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-05-2019, 10:18 AM   #7
blazer2007
Since your in Tacoma phone the old car center in Van.B.C. They sell WV but they told me of another place in Ca. not stockton wheel but another that I can,t remember. They said people were getting PO at the wait time from WV
blazer2007 is offline   Reply With Quote
Old 06-05-2019, 01:02 PM   #8
Loco83
Loco83's Avatar
Probably these guys,
https://thewheelsmith.net/wheel-catalog
Loco83 is online now   Reply With Quote
Old 06-05-2019, 01:29 PM   #9
dagnabbitt
dagnabbitt's Avatar
That sounds bizarre to me, what was their reason for refusing? Unless it is some sort of safety/engineering concern I would call again and try to talk to someone else: custom means custom. I bought the below wheels off of them and they made them to my specs: six bolt, 17 inch, with modern chev backspacing; the truck sits on a 97 Tahoe chassis.
At any rate, I am sure that 4.25 is fine.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 06-05-2019, 06:29 PM   #10
78GMC_truck
Thumbs up Re: Stock and drop formula, wheel vintiques?
Originally Posted by Loco83 View Post
Yup, I just called these guys and they made me the ones I want! The Wheel Smith FTW! Thanks
