Old 06-03-2019, 11:36 AM   #1
DaHos
DaHos's Avatar
Need a Photo np205
I am in the process of swapping my th350 to a th400 in my 71 k20 and I am looking for pics of the NP205 shifter location in the high hump floor (keeping engine in factory location) The th400 moves it back 3" and not sure of clearance......thx !!
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 06-05-2019, 10:50 PM   #2
Blazerowner
Blazerowner's Avatar
Re: Need a Photo np205
Have you considered moving the engine forward instead. Much less work and usually the holes are in the frame already. If not the t-case handle has to be bent to clear into the stock hole. I’ve seen it done with a 4l80.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 06-06-2019, 08:53 AM   #3
DaHos
DaHos's Avatar
Was an abandoned project by others, trans crossmember and tc mount have been moved back and driveshifts have been built, was hoping to use what I have........also running a 292 and cannot move engine forward...prob just mod shifter but was looking for ideas......
1967 C10 SWB
Old 06-06-2019, 05:16 PM   #4
sweetk30
sweetk30's Avatar
i would make a new bracket / mount for the sifter handle and then a pair of hiem ends and threaded rod for a new link and be done with it .
this is a bit crazy but here is my custom mount for 5 levers . i built it off the top 4 bolts for the round 6 pattern adapter to the 203 range box on the 4l80-e to 241 adapter i used for the doubler .
its just plate and 2 shifter kits from offroad design i modifyed .
#1 - pto pump in/out for hydro winch
#2 - in cab winch control
#3 - 203 range box H/N/L
#4 - rear output of 205 control H/N/L
#5 - front output of 205 control H/N/L
#6 lokar auto trans lever with linkage kit to make it work all the way up were its mounted back to the link point and then down to the trans arm .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 06-06-2019, 05:27 PM   #5
sweetk30
sweetk30's Avatar
then when its ready for install i have the floor hump all layed out for the 3 boots . also will be using a stock sm465 shifter boot on the lokar shifter . and with its black shaft it will look like a 4 speed trans shifter .
Old 06-08-2019, 03:53 PM   #6
HO455
HO455's Avatar
Too cool!
RIP Bob Parks.
Old 06-08-2019, 04:09 PM   #7
sweetk30
sweetk30's Avatar
ya anti-theft kit for gear heads . 6 levers who the heck will figure it all out even with a sticker showing the combo .
