Old 06-02-2004, 06:41 PM   #1
BamaGN
BamaGN's Avatar
Difference between Tilt column out of a Van
What is the difference, if any, between a tilt column out of a 70s van and a 70s truck? They look the same to me, but I read somewhere a van column had to be cut.
Bass
1972 Chevy Truck Short Bed 402 BB
1987 Buick Grand National, not stock
1969 Camaro SS 454, definitely not stock, Fogger
1982 S-10 truck 350
1970 GMC Truck Long Bed 402 BB
1997 Camaro Z28 M6
BamaGN is offline   Reply With Quote
Old 06-02-2004, 07:18 PM   #2
71swb4x4
71swb4x4's Avatar
The van column has a longer shaft, so the shaft between the tilt and the steering box needs to be "crushed." This is an easy mod. The neutral safety switch on the van column needs to be moved as well but this is not tough. The last thing you will have to do is get an adapter for the wiring harness (a few do not need this). Most vans have the flat wiring plug while the trucks have the curved wiring plug.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-02-2004, 07:23 PM   #3
71swb4x4
71swb4x4's Avatar
http://67-72chevytrucks.com/vboard/s...threadid=63328
Here is a thread on relocating the nuetral safety switch.
Old 06-02-2004, 07:27 PM   #4
71swb4x4
71swb4x4's Avatar
http://67-72chevytrucks.com/vboard/s...d.php3?t=82087
Here is another great thread.
Old 06-03-2004, 12:51 AM   #5
BamaGN
BamaGN's Avatar
Thanks for the help. I know where a couple are that I need.
Bass
1982 S-10 truck 350
1997 Camaro Z28 M6
